Dos anyone know of any good rain radar integrations?
I am interested in Central Europe, especially Poland, Slovakia and Hungary areas.
What I found to work best for me (right now anyway) is a webpage card that grabs from windy.com. (Looks like they cover that area.)
You can point the windy.com website to your location, zoom in/out as you need, then grab the embedded map code and add a webpage card to your lovelace.
Thanks.
Can you tell me how to grab the embedded map code?
What does it look like? Can you show an example map code?
Let me try this again. Use a webpage card with this configuration:
type: iframe
url: >-
https://embed.windy.com/embed2.html?lat=50.047&lon=19.693&zoom=5&level=surface&overlay=radar&menu=&message=true&marker=&calendar=&pressure=&type=map&location=coordinates&detail=&detailLat=50.047&detailLon=19.693&metricWind=mph&metricTemp=%C2%B0F&radarRange=-6
aspect_ratio: 81.5%
title: Windy Radar
Sure… when you go to windy.com and input you location, you can pull out the left side menu and click on “embed widget on page” (see below)
That brings up a page to make adjustments and then grab the code:
The generated code would look something like this:
<iframe width="650" height="450" src="https://embed.windy.com/embed2.html?lat=42.850&lon=-78.959&detailLat=42.890&detailLon=-78.880&width=650&height=450&zoom=7&level=surface&overlay=radar&product=radar&menu=&message=&marker=&calendar=now&pressure=&type=map&location=coordinates&detail=&metricWind=default&metricTemp=default&radarRange=-1" frameborder="0"></iframe>
When you go to add it to a lovelace webpage card… format the embed code like this (remove the iframe stuff):
Thanks for the assist! (I was just getting around to answer and you beat me to it! LOL.)
I also use this weather radar card, available via HACS. It works nicely.
Thank you both.
It is working.
Do you know if default “playing time” is configurable? It seems to be 60 minutes.
Look for something in the URL that says radarRange=-1
, which would be 1 hour. You can change it to - 6
or -12
, perhaps more. Give it a try.
Thanks but changing to higher values is not reflected in playing time.
Did you refresh your browser cache when you changed it?
I guess I did.
I’m afraid 6-hour and 12-hour loops may be available to premium users only.
Many browsers will reload if you use the <ctl><F5>
key combination.
If you see this at the bottom right, the three options are available:
Yes, 6h and 12h options are available but clicking them brings up subscription window.
The yearly Premium subscription on windy is like 20 EUR (less actually, but I cannot remember how much). I signed up, because it adds the long term forecast, and the 1 hour steps in forecast as well.
If you do sign up, go to the Community forum and ask about their API for home automation use.
They currently don’t have any for this kind of purposes, and would be nice to add it to HA if they would develop it.
If you want to get fancy you can use the config-template-card with a device tracker entity that contains lat/long coordinates and use that within the windy url to have weather based on your location:
type: custom:config-template-card
entities:
- sensor.pixel_6_pro_geocoded_location
card:
type: custom:hui-iframe-card
title: null
url: >-
${'https://embed.windy.com/embed2.html?lat='+states['sensor.pixel_6_pro_geocoded_location'].attributes.location[0]+'&lon='+states['sensor.pixel_6_pro_geocoded_location'].attributes.location[1]+'&detailLat='+states['sensor.pixel_6_pro_geocoded_location'].attributes.location[0]+'&detailLon='+states['sensor.pixel_6_pro_geocoded_location'].attributes.location[1]+'&width=650&height=450&zoom=6&level=surface&overlay=rain&product=ecmwf&menu=&message=true&marker=true&calendar=now&pressure=true&type=map&location=coordinates&detail=&metricWind=mph&metricTemp=%C2%B0F&radarRange=-1'}
aspect_ratio: 135%
That is really fancy! Thanks for sharing!
I get this error:
“Custom element doesn’t exist: config-template-card.”
I understand I first need to create config-template-card. Right? How to do that?
You would need to install config-template-card from GitHub - iantrich/config-template-card: đź“ť Templatable Lovelace Configurations via HACS or manually then the config I posted should work. My apologies for not clarifying in my original post.
Thanks. I have only recently installed HACS so I’m not proficient in it.
How do I install config-template-card using HACS?
Should I do it through “Add repository”? What do I put in the search box?
