Rain sensor [Help]
I’m trying to create a simple rain detection sensor that basically acts as a switch to help home assistant decide whether it should skip spraying my garden with dipel on a rainy day as it will likely wash off.
I’m simplifying the project found here
I have a pcb with traces on it connected to a weemos d1 mini with a reference resistor. I’m trying to convert the resistance to a simple on (wet) or off (dry) message but get the following compile error " Unable to find action with the name ‘sensor.template.publish’. sensor.template.publish: [source /config/esphome/rain-sensor.yaml:57] id: real_resistance_sensor state: !lambda |- return ON; "
I’ve had it working previously but had to rewrite the code from scratch and cant figure out what I’m doing wrong. As far as i could read in the docs sensor.template.publish action still exists?
**Any help would be appreciated
Below is my code
esphome:
esp8266:
  board: d1_mini
# Enable logging
logger:
# Enable Home Assistant API
api:
ota:
  password: !secret ota_password
wifi:
  ssid: !secret wifi_ssid
  fast_connect: true
  ap:
    ssid: "Rain-Sensor Fallback Hotspot"
    password: !secret ap_password
captive_portal:
switch:
  - platform: gpio
    pin: D0
    name: "Rain sensor powerr"
  - platform: adc
    pin: A0
  - platform: resistance
    icon: "mdi:omega"
    internal: true
    sensor: source_sensor
    configuration: DOWNSTREAM
    resistor: 5.1kOhm
    reference_voltage: 3.3
    on_value:
    then:
      - if:
        condition:
        lambda: |-
        return (
        id(real_resistance_sensor).state > 100
       then:
        - sensor.template.publish:
          state: !lambda 'return ON;'
Could you please post your code properly, at the moment I see a backtick ` at the start of each line.
Hi, sorry about that. I tried asking to reddit also and had no luck, didn’t pickup on the different formatting. Should be fixed. Lost the original code again, so had to quickly correct it again
Just add an internal dummy template sensor, so the right files and libs are included in the build process.
binary_sensor:
Something like this?
Yes and I would add
    internal: true
to avoid exposing the dummy sensor to HA.
thank you for taking the time to help me. Ill give that a go and report back
