Rainbird Integration only runs sprinklers for 5 minutes
A recently added Rain bird sprinkler integration.
I can control the sprinklers, but they only stay turned on for 5 minute intervals. If I throw the switch, they turn off on their own after 5 minutes. If I use the start_irrigation service, setting the duration for 15 minutes, they turn off after 5 minutes.
What am I doing wrong? Thanks
I’m having the same issue. Did you ever find a way to solve this?
Same issue here.
Mine is every 6min … it goes off is there any resolution or work around on this? Thank you
Make sure that the controller/app is not overriding your HA schedule.
I figured this out, finally!
The Rainbird integration configuration defaults to 6 minutes when you manually turn on a station. You need to update the Rainbird configuration with a new default irrigation time. Attaching a screenshot.
Hi, was looking for this too!
So this still gives an option to stop watering earlier then the default time, right?
Guys, wanna share something that I just found: Irrigation Custom Component with Custom Card
Aaah, this was killing me the last day… couldn’t figure it out.
This component should ask this question in the config_flow (setup), so users are aware of this. Anyway, working like a charm now! Thanks!
Thanks, this is the solution
