Not sure if this will be the proper place to post…
But could someone tell me how many Ram
Does use home assistant android app?
Reason im asking is…
I did post in another posting
That the app gets out of focus …
Now i did finally found out why. … …
This samsung a8 tablet
Is what i use for wall panel mode home assistant
But it closes because it gets out of Ram mem
Now i saw that it uses over 1.7 gig of ram…
That’s why i ask now if this is normal?
Fill me in pls …
Thank You …
RAM usage totally depends on your dashboard setup, not easy to answer but should be similar to a browser.
Thank You for the reply dshokouhi…
So im still not sure if 1.7 gigs of Ram
Is alot or not .
But if it is the case…then i need
A new tablet with atleast 8 gigs ram…
Lets hear what ohters has to say too…
If you go on Home Assistant Demo and hold your mouse over the Chromium tab, the whole page consumes 38.8MB, so for some reason your using nearly 50x the demo does in a browser…
Thank You to for the reply Stuart…
And this is exact the reason why i ask…
On server side it uses only 1.2 gigs on a pi 4 and ssd…
Runs smooth never issues…
But using this tablet in wall mode it uses since 8 months
This extreem high ram usage…
And i dunno why yet… .
What i do known is that is goes pretty fast to 1.7 gigs
But no weird errors in logs
And all stuff works fine…till the ram is up…
