Ramses_cc broke after core update
Hey,
after updating the core to 2024.12.5 the ramses_cc integration showed the next error message and did not load anymore.
Anybody any idea what is missing or how to tackle the error.
The log is posted underneath.
Thanks for any hint.
And happy new year
Logger: homeassistant.setup
Source: setup.py:334
First occurred: 19:51:56 (1 occurrences)
Last logged: 19:51:56
Setup failed for custom integration ‘ramses_cc’: Unable to import component: cannot import name ‘Entity’ from ‘ramses_rf.entity_base’ (/usr/local/lib/python3.13/site-packages/ramses_rf/entity_base.py)
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1014, in async_get_component
comp = await self.hass.async_add_import_executor_job(
self._get_component, True
File “/usr/local/lib/python3.13/concurrent/futures/thread.py”, line 58, in run
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1074, in _get_component
ComponentProtocol, importlib.import_module(self.pkg_path)
File “/usr/src/homeassistant/homeassistant/util/loop.py”, line 200, in protected_loop_func
return func(*args, **kwargs)
File “/usr/local/lib/python3.13/importlib/init.py”, line 88, in import_module
return _bootstrap._gcd_import(name[level:], package, level)
File “”, line 1387, in _gcd_import
File “”, line 1360, in _find_and_load
File “”, line 1331, in _find_and_load_unlocked
File “”, line 935, in _load_unlocked
File “”, line 1022, in exec_module
File “”, line 488, in _call_with_frames_removed
File “/config/custom_components/ramses_cc/init.py”, line 26, in
from ramses_rf.entity_base import Entity as RamsesRFEntity
ImportError: cannot import name ‘Entity’ from ‘ramses_rf.entity_base’ (/usr/local/lib/python3.13/site-packages/ramses_rf/entity_base.py)
File “/usr/src/homeassistant/homeassistant/setup.py”, line 334, in _async_setup_component
component = await integration.async_get_component()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1034, in async_get_component
self._component_future.result()
File “/usr/src/homeassistant/homeassistant/loader.py”, line 1026, in async_get_component
comp = self._get_component()
