Random brightness values from Lutron Aurora dimmer
Hey folks, new here, so first thanks for the tremendous resource!
Second, I’ve been struggling to get my Lutron Aurora working via Zigbee as well as it was working connected directly to my Hue hub. The first problem was sporadic events from button presses, and that turned out to be a problem with the Zigbee receiver I was using.
Now, I have it connected to a Conbee II and I’m getting all the events, but the dimmer events seem to just provide nonsense values for the brightness (arg 0). I just ran a test, turning it only clockwise, and I received… 22, 22, 22, 30, 2, 2, 88, 51, 59, 95, 102, 30.
If these were speed values, I could work with that (if I had a way to get the direction the dimmer is being turned). But there’s no distinguishing between clockwise and counterclockwise turns. And just to be clear, this switch works 100% fine when connected via the Friends of Hue integration within the Hue app.
Am I missing something obvious here?
Thanks!
And actually, with more testing, counter-clockwise always send a value of 2. So, funny enough, I might actually be able to use that as a workaround. But I still would rather get it working properly if I can.
