I am suggesting a new Building Block for automation actions called “Random Choice.”
It would act similarly to the “Choose” action, however instead of setting conditions you would just add as many Options to the Random action as you want, and when triggered, HA would select one randomly to run.
Here is an example use case: For your morning alarm (or nighttime white noise), you have a list of possible sounds or songs you would like to play, but a random one each day. You can quickly add each song as an Option to the Random action and it would do the randomization for you.
Another example: You want to have your lights come on and off while you are away from home, but you do not want them to sequence in a pattern that can be recognized by a potential thief. Using the Random action to add different room lights to the action would pick different rooms randomly, more closely representing someone being home. (This is where a random timing trigger would also be useful)
Anyone else think this would be useful? Yes, I know you can do this in templates. I know you can also make a Random Helper and feed that number into the Choose action. But that is a lot of extra steps, and you have to change the random helper each time you want to add an additional Option to the automation.
Besides the technical aspect I think it’s worth pointing out that randomness isn’t psychologically straight forward: humans can struggle with this. There’s been studies to show that if you ask people to make up random sequences that they turn out not to be so random, yet we think it is. It’s also how you can detect certain kinds of financial fraud.
Very much simplified, there are different kinds of randomness and whether (for example) you want repetition or not can highly affect how you perceive randomness.
If you get the same result 10 times in a row many people will react with: “That’s not random!” It surely may be probabilisticly highly unlikely, but it may well still be random.
So, my point is: There isn’t a single solution for what constitutes “random”. It depends on the specific case. It’s an enormous field of study where not everything can be reduced to a coin flip.
In the case of sounds or music, initially shuffled playlists used simple uniform distributions, but this lead to certain tracks perceived to be played too often. Etc. Then some smart people came along and created the Knuth/Fisher-Yates shuffle and today it’s even more advanced using machine learning and such.
random:
- sequence:
- service: google_generative_ai_conversation.generate_content
metadata: {}
prompt: >-
Create a short announcement like a medieval herald for an angelic
princess named Daphne who is just waking up. It should be glamorous
and regal. The announcement should be about 50 words long
response_variable: proclamation
enabled: true
alias: Gemeni Herald (Angelic)
- service: tts.google_cloud_say
metadata: {}
cache: false
entity_id: "{{ media_target }}"
message: "{{ proclamation[\"text\"] }}"
options:
voice: en-IN-Neural2-D
gender: female
speed: 0.8
pitch: -1
alias: Google TTS from Gemini (Indian English)
- sequence:
metadata: {}
prompt: >-
Create a short announcement like a medieval herald for an evil
threatening the audience and ominous. The announcement should be
about 50 words long
enabled: true
alias: Gemini Herald (Evil)
metadata: {}
cache: false
alias: Google TTS from Gemini (Deep British Male)
- sequence:
metadata: {}
prompt: >-
Create a short announcement like a medieval herald for an enchanted
forest princess named Daphne who is just waking up. It should be
magical and directed towards the animals in her kingdom. The
enabled: true
alias: Gemini Herald (Enchanted)
metadata: {}
cache: false
options:
voice: fr-FR-Polyglot-1
gender: male
speed: 0.95
pitch: -1
alias: Google TTS from Gemini (French Male)
Thanks. As I said in the post, I know it can be done in templating. I’m suggesting it be added to the UI as an automation Building Block for ease of use, since HA is moving in that direction.
Effectively, it’s a list of actions and Home Assistant would randomly select one for execution. It replaces templating with duplication (entire actions are replicated with minor alterations).
For automating my home, I haven’t found a need for employing randomness except for one instance and I encountered the “perception of non-randomness” explained by parautenbach. It’s more evident when random choices are made over short intervals of time, such as when playing songs or displaying colors.
As a consequence, I had to shuffle the list first then iterate through it in sequence. After the last item in the list was used, the list was re-shuffled.
Personally, I wouldn’t have a use for this FR but I think it would make it easier to implement “random actions” for users (especially for anyone uncomfortable with templating). As long as they understand that, depending on their application, the end-result might not “feel” as random as they expected.
metadata: {}
prompt: >-
{{ ("Create a short announcement like a medieval herald for an angelic
and regal. The announcement should be about 50 words long",
"Create a short announcement like a medieval herald for an evil
"Create a short announcement like a medieval herald for an enchanted
announcement should be about 50 words long") | random }}
enabled: true
metadata: {}
cache: false
options:
gender: male
speed: 0.95
pitch: -1
In the first example of lordratner’s post, each prompt message has associated voice, gender, speed, and pitch parameters. To replicate that functionality, you would need to create a list of dictionary items, randomly select one of the dictionary items, then use the values of its prompt, voice, gender, etc keys in the service call.
I have a vague recollection of creating such an example for someone else. I’ll post a link if I find it.
I found the post I was thinking of. The user had wanted to randomly pick one of several options in a choose statement. In other words, it’s very similar to the example you posted containing several sequences where one would be chosen at random.
Borrowing from that example, your “random choice of actions” would look like the following example. It’s structure is similar to what you had proposed.
Example: Random choice of actions
- variables:
i: "{{ [1,2,3] | random }}"
- choose:
- conditions: "{{ i == 1 }}"
sequence:
metadata: {}
prompt: >-
enabled: true
metadata: {}
cache: false
options:
gender: female
speed: 0.8
pitch: -1
- conditions: "{{ i == 2 }}"
sequence:
metadata: {}
prompt: >-
about 50 words long
enabled: true
metadata: {}
cache: false
- conditions: "{{ i == 3 }}"
sequence:
metadata: {}
prompt: >-
enabled: true
metadata: {}
cache: false
options:
gender: male
speed: 0.95
pitch: -1
FWIW, my preference would be to separate the data from the service call by using variables.
I wanna just say that I still think this would be a good addition as a Building Block specifically so this type of advanced templating is not necessary. But until then:
Is there a jinja function to count the number of entries in a variable? The goal is to change this line:
phrase: "{{ phrases([0,1,2] | random) }}"
into something that does not need to be updated each time a new option is added to the “phrases” variable. In python it would be the count() function. Not sure exactly how it would work since it seems the random function in jinja seems to need the options listed explicitly.
Either way, thanks, this’ll at least help me clean up the code.
