I’m running on a Raspberry 4, Ubuntu 19.10 and Home Assistant is in Docker.
Each time I reboot some of the containers, especially influxDB (but this happend with others) change their IP which breaks everything till I change the config files.
Is there any way to get statis IPs for the containers ? Who is responsible for giving the 172.x.x.x IPs ? And how to configure it ?
I don’t think I’m supposed to change config files according to new IP after each reboot, no ?
That would be from docker itself. Typically you want to use the container name rather than the IP address to connect. For example my docker-compose for nextcloud, when I connect to the postgres database I use db:5432 rather than 172.x.x.x:5432
So I’ll have to learn how to use a Docker compose file, I don’t even know where is this file for the existing containers of the default install.
Apart from this problem Docker seems to be a really good solution, in particular for updates. I’m wondering if there’s no a more simple solution, something in the configuration.yaml…
