Since a few releases and since I switched to a Pi 3b+ I experience random freezes.
Any ideas how I can debug this since the normal home-assistant.log freezes as well?
Thanks and cheers
Thanks and cheers
Power supply?
Maybe one of your component put I/O in event loop. Did you see warning message such as āTimer got out of sync. Resettingā
@VDRainer: Good point, I used the old 2.0A-supply from my old Pi. After reading a bit, I ordered a 2.5A-power supply. Iāll report back in a few days.
What I am still wondering about is the fact, that the Pi per se is still working - I can ssh into it - just the HASS-process stopped. With an easy systemctl restart, everything is back to normal.
@awarecan: No, thatās the odd part. No error message whatsoever. It just stops logging/working.
The power supply did the trick. No more freezes for a few days. Thanks a lot!
