I have been trying to get an automation working that randomly turns on & then off a light.
I have two triggers:
One is when the current time is equal to a randomly generated time.
The other is an input_boolean that i want to control the functioning of the automation in a loop such that it restarts itself repeatedly until a predetermined thing occurs (as yet to be determined).
I have gotten the time based trigger to work. I haven’t been successful with the input_boolean control.
here is the code:
- alias: Random Livingroom Lights
value_template: "{{ is_state('sensor.time', '%02d'|format(states('input_slider.random_hour_lr')|int) ~ ':' ~ '%02d'|format(states('input_slider.random_minute_lr')|int)) }}"
- platform: state
entity_id: input_boolean.bool_4
to: 'on'
condition:
condition: and
conditions:
- condition: state
entity_id: 'sun.sun'
state: 'below_horizon'
- delay: '00:00:10'
- service: homeassistant.turn_off
- delay: '00:{{ (range(1, 5)|random|int) }}:00'
- service: homeassistant.turn_on
entity_id:
- light.zw_light_1_level
- delay: '00:{{ (range(1, 10)|random|int) }}:00'
entity_id:
The first time the automation is run based on the random time, everything works as desired. the lights turn on at a random time in the future, the lights turn off at another random time in the future, the input_boolean turns on.
Then nothing.
I’ve looked at the logbook and it says that the automation is triggered when the input_boolean is turned on but the sequence never progresses after that. the input_boolean should turn off after 10 seconds but it doesn’t and the light never cycles.
If I try to trigger the automation by manually turning off then on the boolean it doesn’t trigger.
Anyone see any problem with the code?
