I have an automation which plays a melody on a zigbee sirene when the doorbell button is pressed.
The melody is a number from a option list from 1 to 18. In the example below the selected melody is 3.
How can I select a random option from this list when the doorbell is activated?
Thanks for you reply.
Unfortunately this gives me the error thath the value {{ range(1, 18) | random }} is not valid.
I did use the double quotes around the function.
Dunno then, I don’t have the same device as you - the entry below has been tested and works to randomly change the value of an input select. Maybe that can help you work it out.
