Hello everyone,
I have a strange problem with my HA on a RaspPi3 model B. Basically, I have been using this combination for years without any problems, but since our move and the change to a new smart home system, I have the problem that the system restarts sporadically and unexpectedly. After this restart, it works perfectly again, and there are no problems until a restart.
Compared to the old system, I have hardly installed any integrations, HACS and add-ons. The old system was a patchwork quilt. With the new system, I made sure I had a homogeneous system. It mainly runs Homematic, plus Hue, Fritzbox and Netatmo. The number of automations is also significantly lower than before, as many things are already controlled directly by Homematic and the HA server only takes on additional control tasks.
The only add-ons installed are Samba share and Mosquitto Broker.
That’s it, in the old system I had a lot more installed without any problems, I also had AdGuard running… Because HmIP does a lot internally (windows open and such), there is also significantly less automation running here than in the old system (both in terms of complexity and number), so the new one should have significantly less to do than before.
Blockquote
2024-12-04 06:55:06.334 WARNING (MainThread) [supervisor.addons.addon] Watchdog found addon Samba share is unhealthy, restarting…
2024-12-04 06:58:00.065 WARNING (MainThread) [supervisor.addons.addon] Timeout while waiting for addon Samba share to start, took more than 120 seconds
2024-12-04 08:34:44.686 WARNING (MainThread) [supervisor.misc.tasks] Watchdog missed an Home Assistant Core API response.
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/udev.sh
[07:37:21] INFO: Using udev information from host
cont-init: info: /etc/cont-init.d/udev.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun supervisor (no readiness notification)
services-up: info: copying legacy longrun watchdog (no readiness notification)
s6-rc: info: service legacy-services successfully started
[07:37:21] INFO: Starting local supervisor watchdog…
2024-12-04 08:37:32.652 WARNING (SyncWorker_0) [supervisor.host.sound] Can’t update PulseAudio data: Failed to connect to pulseaudio server
2024-12-04 08:37:45.968 ERROR (MainThread) [supervisor.backups.backup] Can’t read backup tarfile /data/backup/496516c0.tar: empty file
