Full details
2020-09-27 20:36:11 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry FrMesh6Router (Gateway) for upnp
File "/usr/local/lib/python3.8/xml/etree/ElementTree.py", line 1693, in feed
self.parser.Parse(data, 0)
xml.parsers.expat.ExpatError: not well-formed (invalid token): line 2, column 45
File "/usr/src/homeassistant/homeassistant/config_entries.py", line 228, in async_setup
result = await component.async_setup_entry(hass, self) # type: ignore
File "/usr/src/homeassistant/homeassistant/components/upnp/__init__.py", line 111, in async_setup_entry
device = await async_discover_and_construct(hass, udn, st)
File "/usr/src/homeassistant/homeassistant/components/upnp/__init__.py", line 76, in async_discover_and_construct
return await Device.async_create_device(hass, location)
File "/usr/src/homeassistant/homeassistant/components/upnp/device.py", line 74, in async_create_device
upnp_device = await factory.async_create_device(ssdp_location)
File "/usr/local/lib/python3.8/site-packages/async_upnp_client/client_factory.py", line 52, in async_create_device
root = await self._async_get_url_xml(description_url)
File "/usr/local/lib/python3.8/site-packages/async_upnp_client/client_factory.py", line 295, in _async_get_url_xml
root = DET.fromstring(response_body) # type: ET.Element
File "/usr/local/lib/python3.8/site-packages/defusedxml/common.py", line 131, in fromstring
parser.feed(text)
File "/usr/local/lib/python3.8/xml/etree/ElementTree.py", line 1695, in feed
self._raiseerror(v)
File "/usr/local/lib/python3.8/xml/etree/ElementTree.py", line 1602, in _raiseerror
raise err
File "<string>", line None
xml.etree.ElementTree.ParseError: not well-formed (invalid token): line 2, column 45
2020-09-27 20:36:13 ERROR (MainThread) [homeassistant.config_entries] Error setting up entry 192.168.0.99 for synology_dsm
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 426, in _make_request
six.raise_from(e, None)
File "<string>", line 3, in raise_from
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 421, in _make_request
httplib_response = conn.getresponse()
File "/usr/local/lib/python3.8/http/client.py", line 1347, in getresponse
response.begin()
File "/usr/local/lib/python3.8/http/client.py", line 307, in begin
version, status, reason = self._read_status()
File "/usr/local/lib/python3.8/http/client.py", line 268, in _read_status
line = str(self.fp.readline(_MAXLINE + 1), "iso-8859-1")
File "/usr/local/lib/python3.8/socket.py", line 669, in readinto
return self._sock.recv_into(b)
File "/usr/local/lib/python3.8/ssl.py", line 1241, in recv_into
return self.read(nbytes, buffer)
File "/usr/local/lib/python3.8/ssl.py", line 1099, in read
return self._sslobj.read(len, buffer)
socket.timeout: The read operation timed out
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 439, in send
resp = conn.urlopen(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 726, in urlopen
retries = retries.increment(
File "/usr/local/lib/python3.8/site-packages/urllib3/util/retry.py", line 403, in increment
raise six.reraise(type(error), error, _stacktrace)
File "/usr/local/lib/python3.8/site-packages/urllib3/packages/six.py", line 735, in reraise
raise value
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 670, in urlopen
httplib_response = self._make_request(
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 428, in _make_request
self._raise_timeout(err=e, url=url, timeout_value=read_timeout)
File "/usr/local/lib/python3.8/site-packages/urllib3/connectionpool.py", line 335, in _raise_timeout
raise ReadTimeoutError(
urllib3.exceptions.ReadTimeoutError: HTTPSConnectionPool(host='192.168.0.99', port=5001): Read timed out. (read timeout=10)
File "/usr/local/lib/python3.8/site-packages/synology_dsm/synology_dsm.py", line 255, in _execute_request
resp = self._session.get(
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 543, in get
return self.request('GET', url, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 530, in request
resp = self.send(prep, **send_kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/sessions.py", line 643, in send
r = adapter.send(request, **kwargs)
File "/usr/local/lib/python3.8/site-packages/requests/adapters.py", line 529, in send
raise ReadTimeout(e, request=request)
requests.exceptions.ReadTimeout: HTTPSConnectionPool(host='192.168.0.99', port=5001): Read timed out. (read timeout=10)
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 163, in async_setup_entry
await api.async_setup()
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 255, in async_setup
await self._hass.async_add_executor_job(self._fetch_device_configuration)
File "/usr/local/lib/python3.8/concurrent/futures/thread.py", line 57, in run
File "/usr/src/homeassistant/homeassistant/components/synology_dsm/__init__.py", line 323, in _fetch_device_configuration
self.utilisation = self.dsm.utilisation
File "/usr/local/lib/python3.8/site-packages/synology_dsm/synology_dsm.py", line 351, in utilisation
data = self.get(SynoCoreUtilization.API_KEY, "get")
File "/usr/local/lib/python3.8/site-packages/synology_dsm/synology_dsm.py", line 179, in get
return self._request("GET", api, method, params, **kwargs)
File "/usr/local/lib/python3.8/site-packages/synology_dsm/synology_dsm.py", line 223, in _request
response = self._execute_request(request_method, url, params=params, **kwargs)
File "/usr/local/lib/python3.8/site-packages/synology_dsm/synology_dsm.py", line 275, in _execute_request
raise SynologyDSMRequestException(exp)
synology_dsm.exceptions.SynologyDSMRequestException: {'api': None, 'code': -1, 'reason': 'Unknown', 'details': "ReadTimeout = HTTPSConnectionPool(host='192.168.0.99', port=5001): Read timed out. (read timeout=10)"}
