A script that allow you to define how many items to enqueue to media_player. Best used with RFID Tag based automation, e.g. a tag scan that randomly play all final fantasy album/tracks, but limited in scope to reduce the amount of API calls.
You can edit the variables ONLY in the first block. The rest are templated.
# By D.Sync (dsync89)
# Last Update: June 2, 2024
# Version: 1.0
# Inspired by @ministryofsillywalks
# This script further enhance the script by @ministryofsillywalks to enqueue the tracks
alias: Play Random Track/Album limited to user defined number
sequence:
- variables: # user-defined variables
search_name: final fantasy # keyword to search
search_limit: 500 # how many items to search, default is very little, so we have to explicitly set it here
play_queue_item_limit: 5 # how many items out of the search_limit to add to the play queue. NOTE: the limit does not apply if album is included in search_media_type because it will add all tracks in that album
search_media_type: # currently support track and album
- track
- album
target_entity_id: media_player.shield_3
log: false # set to true to log to logbook
# DO NOT MODIFY
- service: mass.search
limit: "{{ search_limit }}"
name: "{{ search_name }}"
media_type: "{{ search_media_type }}"
response_variable: results
# - service: logbook.log
# data:
# name: "Search Results"
# message: "{{ results.tracks | tojson }} items found."
- variables:
all_items: >
{% set items = [] %}
{% if results.tracks is defined %}
{% set items = items + results.tracks %}
{% endif %}
{% if results.albums is defined %}
{% set items = items + results.albums %}
{% endif %}
{{ items }}
selected_items: >
{% set items = all_items %}
{% set ns = namespace(items=[]) %}
{% for i in range(play_queue_item_limit) %}
{% set item = items | random %}
{% set ns.items = ns.items + [item] %}
{% set items = items | reject('equalto', item) | list %}
{% endfor %}
{{ ns.items }}
- choose:
- conditions:
- condition: template
value_template: "{{ log }}"
sequence:
message: "Selected Items: {{ selected_items | tojson }}"
- service: mass.play_media
media_id: "{{ selected_items[0].uri }}"
enqueue: replace # replace the existing play queue
entity_id: "{{ target_entity_id }}"
- repeat:
count: "{{ play_queue_item_limit - 1 }}"
sequence:
media_id: "{{ selected_items[repeat.index].uri }}"
enqueue: add # add the remaining items to the play queue
mode: single
icon: mdi:album
