Having already configured an NFC Tag and wanting to use this to randomly play different playlists from Spotify on my favorite media player, is there anyone experienced who can create an automation blueprint?
This should be in Configuration > Blueprints, not Blueprints Exchange.
You are indeed posting in the wrong section. This is only for sharing Blueprints.
Ok, sorry…
Ok i will change my request:
Is it possible to use the random option inside a blueprint automation?
If yes, how?
Which random option?
What you call a ‘blueprint automation’ is basically an automation with a UI to configure it. The automation itself follows the same guidelines, and has access to the same resources, as a ‘traditional’ automation.
I suggest you create an automation that works the way you want then convert it to a blueprint.
Yes, there is a random filter in Jinja2.
Yes, i am aware about blueprint but i am not so good expert about automations creation especially if i am forced to use templates, so i asked it in hope that someone has already created an automation like this.
BTW thanks for the suggestion…
My mistake. When you asked if random
was available “inside a blueprint automation” I thought you were doing research prior to creating the blueprint yourself. You’re just wondering if it exists because it might mean someone has used it to create the blueprint you want.
You might have better luck searching the forum for an existing automation that randomizes playlists. If you cannot adapt it to your needs, you could ask someone to help you or to convert it to a blueprint for you.
Good luck!
Ok, I’ll try to find something related and then try to create a blueprint or in case I don’t have success I’ll ask someone to convert…
