Randomly working automation with input_text and template
In Stockholm the local radio tweets traffic information. I use the quite standard scrape sensor to get it in to HA.
This is the sensor (that works fine)
  - platform: scrape
    name: Trafik P4 Stockholm
    resource: https://twitter.com/TrafikP4Sthlm
    select: ".js-tweet-text-container .tweet-text"
After using this sensor, I realized that it some days the latest tweet is only valid for minutes and I only see the latest. Therefore I build a stack of FIFO for the tweets using input_text.
To keep the interest, I start with the automation the randomly works then I will give you the full automation. Please note that the day and time part works.
As said, this works, some times!!!
  - data_template:
      entity_id: input_text.trafik_7
      value: "{{ states.sensor.trafik_p4_stockholm.state.split ('http') [0] }}"
    service: input_text.set_value
(tried without the “split” it is still working randomly)
Here is the full automation.
- id: '1580301033027'
  alias: test trafik
  description: ''
  - event_data:
      entity_id: sensor.trafik_p4_stockholm
    event_type: state_changed
    platform: event
  condition: []
#   - data_template:
#       entity_id: input_text.trafik_6
#       value: '{{ states.input_text.trafik_5.state }}'
#     service: input_text.set_value
#   - data_template:
#       entity_id: input_text.trafik_time_6
#       value: '{{ states.input_text.trafik_time_5.state }}'
  - data_template:
      entity_id: input_text.trafik_5
      value: '{{ states.input_text.trafik_4.state }}'
  - data_template:
      entity_id: input_text.trafik_time_5
      value: '{{ states.input_text.trafik_time_4.state }}'
  - data_template:
      entity_id: input_text.trafik_4
      value: '{{ states.input_text.trafik_3.state }}'
  - data_template:
      entity_id: input_text.trafik_time_4
      value: '{{ states.input_text.trafik_time_3.state }}'
  - data_template:
      entity_id: input_text.trafik_3
      value: '{{ states.input_text.trafik_2.state }}'
  - data_template:
      entity_id: input_text.trafik_time_3
      value: '{{ states.input_text.trafik_time_2.state }}'
  - data_template:
      entity_id: input_text.trafik_2
      value: '{{ states.input_text.trafik_1.state }}'
  - data_template:
      entity_id: input_text.trafik_time_2
      value: '{{ states.input_text.trafik_time_1.state }}'
  - data_template:
      entity_id: input_text.trafik_1
      value: '{{ states.input_text.trafik_7.state }}'
  - data_template:
      entity_id: input_text.trafik_time_1
      value: '{{ states.input_text.trafik_time_7.state }}'
  - data_template:
  - data_template:
      entity_id: input_text.trafik_time_7
      value: '{{ as_timestamp(states.sensor.trafik_p4_stockholm.last_changed)| timestamp_custom("%A %X") }}'
As said, it is a stack first in first out, and it works, now and then:-(
The " time and date thing works fine.
If you are wondering here is the configuration.yaml.
input_text:
  trafik_1:
    initial: ' '
  trafik_2:
    initial: ' '
  trafik_3:
    initial: ' '
  trafik_4:
    initial: ' '
  trafik_5:
    initial: ' '
  trafik_6:
    initial: ' '
  trafik_7:
    initial: ' '
  trafik_time_1:
    name: Trafik time 1
    initial: ' '
  trafik_time_2:
    name: Trafik time 2
    initial: ' '
  trafik_time_3:
    name: Trafik time 3
    initial: ' '
  trafik_time_4:
    name: Trafik time 4
    initial: ' '
  trafik_time_5:
    name: Trafik time 5
    initial: ' '
  trafik_time_6:
    name: Trafik time 6
    initial: ' '
  trafik_time_7:
    name: Trafik time 7
    initial: ' '
I solved most of the issue. The problem was in definition of input_text in config.yaml.
input_text:
trafik_1:
initial: ’ ’
By default this is 100 characters long, a tweet can be 280 characters. You might think that the first 100 characters would be copied, but no nothing gets copied.
Now I changed the config.yaml to as follows.
  trafik_1:
    initial: ' '
    max: 255
There is still posibilities for glitches, a tweet can as said be 280 charaters and input_text can only be 255, but mostly it works. This is how it looks.
I found another issue, when the tweets somes to close to each other (less than a minute), it might fail as well, I’m trying with a delay in the automation. This is my complete configuration.
config.yaml
input_text:
  trafik_1:
    initial: ' '
    max: 255
  trafik_2:
    initial: ' '
    max: 255
  trafik_3:
    initial: ' '
    max: 255
  trafik_4:
    initial: ' '
    max: 255
  trafik_5:
    initial: ' '
    max: 255
  trafik_6:
    initial: ' '
    max: 255
  trafik_7:
    initial: ' '
    max: 255
  trafik_time_1:
    name: Trafik time 1
    initial: ' '
  trafik_time_2:
    name: Trafik time 2
    initial: ' '
  trafik_time_3:
    name: Trafik time 3
    initial: ' '
  trafik_time_4:
    name: Trafik time 4
    initial: ' '
  trafik_time_5:
    name: Trafik time 5
    initial: ' '
  trafik_time_6:
    name: Trafik time 6
    initial: ' '
  trafik_time_7:
    name: Trafik time 7
    initial: ' '
Automation.yaml
  alias: Övrigt_trafik_tweet
  description: ''
  - event_data:
    platform: event
  condition: []
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - data_template:
  - delay: 00:02:00
  - data_template:
  - data_template:
        %X") }}'
lovelacexxx.yaml
  - type: markdown
    content: >
      ## #Kollektivtrafiken Stockholm
      {{as_timestamp(states.sensor.kolletivtrafiken.last_changed) | timestamp_custom("%A %X") }}
      {{ states.sensor.kolletivtrafiken.state.split('#koll')[0] }}
      {{ states.input_text.buss_time_1.state }}
      {{ states.input_text.buss_1.state }}
      {{ states.input_text.buss_time_2.state }}
      {{ states.input_text.buss_2.state }}
      {{ states.input_text.buss_time_3.state }}
      {{ states.input_text.buss_3.state }}
      {{ states.input_text.buss_time_4.state }}
      {{ states.input_text.buss_4.state }}
      {{ states.input_text.buss_time_5.state }}
      {{ states.input_text.buss_5.state }}
      {{ states.input_text.buss_time_6.state }}
      {{ states.input_text.buss_6.state }}
      https://twitter.com/kollektivkollen
////Tobe
