Range Actions
Range Actions is a Home Assistant automation blueprint that watches one numeric entity and runs actions when the value enters a configured range.
It is designed for threshold-based automations where you need predictable first-match range behavior, reduced edge flapping, and clear context variables for notifications.
What This Blueprint Does
- Monitors one numeric entity (
sensor,input_number, ornumber). - Evaluates ranges in order and uses first-match-wins behavior.
- Runs actions only when a new range is entered.
- Uses a required
input_numberhelper to remember the last entered range. - Keeps the last active range latched across allowed deadband gaps to reduce repeated triggers near thresholds.
- Supports optional extra conditions before actions run.
- Exposes useful template variables about previous/current values and selected range metadata.
Required Entities
- One numeric entity:
sensorinput_numbernumber
- One
input_numberhelper used to remember the last entered range index.
Inputs
Mandatory
- Numeric Entity: Entity whose state is monitored.
- Monitored Ranges: Ordered list of ranges with:
name(required)description(optional)min(required)max(required)
- Remembered Range Helper:
input_numberhelper that stores the last entered range index.
Configure it with:- minimum
-1 - maximum at least
number_of_ranges - 1 - initial value
-1
- minimum
Optional
- Additional Conditions: Extra conditions that must pass before actions execute.
- On Range Entered: Action sequence executed on range entry.
Create The Helper
- In Home Assistant, go to
Settings -> Devices & Services -> Helpers. - Click
Create Helper. - Choose
Number. - Set a name such as
Helper remembered range. - Set minimum to
-1. - Set maximum to at least
number_of_ranges - 1. - Set step to
1. - Set the initial value to
-1. - Select this helper in the blueprint as
Remembered Range Helper.
Available Templates In Actions
{{ monitored_entity }}: Entity ID being monitored.{{ current_value }}: Current numeric value (ornone).{{ remembered_range_index }}: Latched range index stored in the helper (or-1).{{ current_range_index }}: Current matching range index (or-1).{{ entered_range_index }}: Entered range index (or-1).{{ entered_range_name }}: Name of entered range.{{ entered_range_description }}: Description of entered range.{{ entered_range_min }}: Minimum bound of entered range.{{ entered_range_max }}: Maximum bound of entered range.{{ range_was_entered }}: Boolean indicating whether a new range was entered.
Notes
- Ranges are inclusive on both ends.
- Overlapping ranges are allowed, but ordering matters because first match wins.
- Invalid ranges are ignored during evaluation (invalid bound values or
min > max). - The remembered range helper is updated before optional additional conditions are evaluated.
- Because of that, the current range remains remembered even when additional conditions block the action.
- Entry detection compares the current matching range to
remembered_range_index, not to the trigger’s previous state. - This makes it possible to create deadbands between ranges without retriggering repeatedly while the value fluctuates around a threshold.
- The automation uses
mode: queuedso quick successive entries are processed in order.
Example Range Configuration
ranges:
- name: Low
description: Comfortable low level
min: 0
max: 25
- name: Medium
description: Mid range
min: 26
max: 60
- name: High
description: Elevated level
min: 61
max: 100
Example Automation: CO2 Guard Example
alias: CO2 guard
description: >-
Sends CO2 level notifications based on entered ranges while using deadband gaps
and a remembered range helper to reduce repeated edge-trigger spam.
use_blueprint:
path: mimoSK/range-actions.yaml
input:
numeric_entity: input_number.test_sensor_value
ranges:
- name: All clear
description: All Clear. No action needed.
min: 0
max: 1350
- min: 1500
max: 1900
description: >-
CO2 level is above 1500ppm. Ventilation recommended. May cause
drowsiness or reduced focus.
- min: 2000
max: 2900
description: >-
CO2 level is above 2000ppm. Increase ventilation. May cause headaches
or mild sleepiness.
- min: 3000
max: 3900
description: >-
CO2 level is above 3000ppm. Ventilate now! May cause increased
sleepiness or poor concentration.
- name: Very High Levels
description: >-
CO2 level is above 4000ppm. Increase ventilation urgently! May cause
stronger headaches or cognitive impairment.
min: 4000
max: 4900
- name: Critical Levels
description: >-
CO2 level is above 5000ppm. Increase ventilation immediately! May
cause nausea, dizziness, or breathing issues.
min: 5000
max: 999999
additional_conditions:
- condition: template
value_template: >-
{% set co2_normal = current_range_index == 0 %} {% set
range_increased = current_range_index > remembered_range_index %} {% if
range_increased or co2_normal %}
true
{% else %}
false
{% endif %}
entered_range_actions:
- action: notify.<add your device>
metadata: {}
title: "CO2: {{ entered_range_name }}"
message: "{{ entered_range_description }}"
remembered_range_helper: input_number.co2_guard_range_helper
Importing The Blueprint
Option 1: Use “Import blueprint” badge
- Click on “Import blueprint” badge which is at the top of this document.
- Follow the import instructions.
Option 2: Local file import
- Copy
range-actions.yamlto your Home Assistant blueprints path, for example:config/blueprints/automation/<your_namespace>/range-actions.yaml
- Reload automations/blueprints from Home Assistant.
- Create an automation from this blueprint.
