RAPT wifi connected temperature controller (Kegland)
There is already integration with the RAPT Pill Hydrometer & Thermometer is it possible to also add support for the temperature controller? I’d like to remotely configure both as automation and also to use the temperature controller as a percentage-based power controller, which it supports through the UI. I’d like it to work with more sensors than just the pill, hence the HA automation.
Hi Tera,
I found your post and nobody seems to have done it.
I wrote this to be able to control the Temperature Controller through MQTT, which can then be set up with HomeAssistant scripts and sensor templates.
Thanks to fkolacek for their work on this a couple years ago. That was really helpful, but just predates the temperature controller.
For anyone who wants to build this out further, the RAPT API documentation is available at (sorry, new users can’t put more than 2 links in a post) api [dot] rapt [dot] io [slash] index.html
