I’ve got the same problem on a RPI4
Here’s my extended log
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.zigbee.application] Probing /dev/ttyAMA0
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.uart] Connecting to /dev/ttyAMA0 at 115200 baud
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.uart] Opened /dev/ttyAMA0 serial port
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.uart] Toggling RTS/CTS to skip CC2652R bootloader
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.uart] Connected to /dev/ttyAMA0 at 115200 baud
2021-03-14 22:33:15 DEBUG (MainThread) [zigpy_znp.api] Waiting 1s before sending anything
2021-03-14 22:33:16 DEBUG (MainThread) [zigpy_znp.api] Sending bootloader skip byte
2021-03-14 22:33:16 DEBUG (MainThread) [zigpy_znp.api] Waiting 1s or until a reset indication is received
2021-03-14 22:33:17 DEBUG (MainThread) [zigpy_znp.api] Testing connection to /dev/ttyAMA0
2021-03-14 22:33:17 DEBUG (MainThread) [zigpy_znp.api] Sending request: SYS.Ping.Req()
2021-03-14 22:33:20 DEBUG (MainThread) [zigpy_znp.api] Connection to /dev/ttyAMA0 failed, cleaning up
2021-03-14 22:33:20 DEBUG (MainThread) [zigpy_znp.uart] Closing serial port
2021-03-14 22:33:20 DEBUG (MainThread) [zigpy_znp.zigbee.application] Failed to probe ZNP radio with config {'path': '/dev/ttyAMA0', 'flow_control': None, 'baudrate': 115200}
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/zigbee/application.py", line 159, in probe
await znp.connect()
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/api.py", line 259, in connect
self.capabilities = (await self.request(c.SYS.Ping.Req())).Capabilities
File "/usr/local/lib/python3.8/site-packages/zigpy_znp/api.py", line 532, in request
response = await response_future
asyncio.exceptions.CancelledError
await znp.connect()
File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 55, in __aexit__
self._do_exit(exc_type)
File "/usr/local/lib/python3.8/site-packages/async_timeout/__init__.py", line 92, in _do_exit
raise asyncio.TimeoutError
asyncio.exceptions.TimeoutError
2021-03-14 22:33:20 DEBUG (MainThread) [bellows.ezsp] Resetting EZSP
2021-03-14 22:33:23 DEBUG (MainThread) [bellows.ezsp] Unsuccessful radio probe of '/dev/ttyAMA0' port
File "/usr/local/lib/python3.8/site-packages/bellows/ezsp/__init__.py", line 55, in probe
await asyncio.wait_for(ezsp._probe(), timeout=PROBE_TIMEOUT)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 501, in wait_for
raise exceptions.TimeoutError()
2021-03-14 22:33:23 DEBUG (MainThread) [zigpy_deconz.api] Command Command.device_state (0, 0, 0)
2021-03-14 22:33:24 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.device_state' command with seq id '0x02'
2021-03-14 22:33:24 DEBUG (MainThread) [zigpy_deconz.api] Unsuccessful radio probe of '/dev/ttyAMA0' port
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 380, in probe
await asyncio.wait_for(api._probe(), timeout=PROBE_TIMEOUT)
File "/usr/local/lib/python3.8/asyncio/tasks.py", line 494, in wait_for
return fut.result()
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 396, in _probe
await self.device_state()
File "/usr/local/lib/python3.8/site-packages/zigpy_deconz/api.py", line 305, in _command
return await asyncio.wait_for(fut, timeout=COMMAND_TIMEOUT)
2021-03-14 22:33:24 DEBUG (MainThread) [zigpy_cc.uart] Connecting on port /dev/ttyAMA0 with boudrate 115200
2021-03-14 22:33:24 DEBUG (MainThread) [zigpy_cc.uart] Connection made
2021-03-14 22:33:25 DEBUG (MainThread) [zigpy_cc.api] --> SREQ SYS version tsn: None {}
2021-03-14 22:33:25 DEBUG (MainThread) [zigpy_cc.uart] Send: b'\xfe\x00!\x02#'
2021-03-14 22:33:26 DEBUG (MainThread) [zigpy_cc.api] Unsuccessful radio probe of '/dev/ttyAMA0' port
File "/usr/local/lib/python3.8/site-packages/zigpy_cc/api.py", line 279, in probe
await asyncio.wait_for(api._probe(), timeout=COMMAND_TIMEOUT)
2021-03-14 22:33:26 DEBUG (MainThread) [zigpy_zigate.uart] PiZiGate detected
2021-03-14 22:33:26 INFO (MainThread) [zigpy_zigate.common] Put PiZiGate in running mode
2021-03-14 22:33:28 DEBUG (MainThread) [zigpy_zigate.uart] Connection made
2021-03-14 22:33:28 DEBUG (MainThread) [zigpy_zigate.uart] Send: 0x0002 b'01'
2021-03-14 22:33:28 DEBUG (MainThread) [zigpy_zigate.uart] Frame to send: b'\x00\x02\x00\x01\x02\x01'
2021-03-14 22:33:28 DEBUG (MainThread) [zigpy_zigate.uart] Frame escaped: b'\x02\x10\x02\x12\x02\x10\x02\x11\x02\x12\x02\x11'
2021-03-14 22:33:29 DEBUG (MainThread) [zigpy_zigate.api] Unsuccessful radio probe of '/dev/ttyAMA0' port
File "/usr/local/lib/python3.8/site-packages/zigpy_zigate/api.py", line 258, in probe
2021-03-14 22:33:29 DEBUG (MainThread) [zigpy_xbee.api] at command: AP (2,)
2021-03-14 22:33:29 DEBUG (MainThread) [zigpy_xbee.api] Command at (b'AP', b'\x02')
2021-03-14 22:33:30 WARNING (MainThread) [zigpy_xbee.api] at: No response to AP command
2021-03-14 22:33:31 WARNING (MainThread) [zigpy_cc.api] No response for: SRSP SYS version {}
2021-03-14 22:33:34 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:34 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 57600bps, trying 1200 next
2021-03-14 22:33:37 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:37 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 1200bps, trying 2400 next
2021-03-14 22:33:40 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:40 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 2400bps, trying 4800 next
2021-03-14 22:33:43 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:43 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 4800bps, trying 9600 next
2021-03-14 22:33:46 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:46 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 9600bps, trying 19200 next
2021-03-14 22:33:50 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:50 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 19200bps, trying 38400 next
2021-03-14 22:33:53 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:53 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 38400bps, trying 57600 next
2021-03-14 22:33:56 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:56 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 57600bps, trying 115200 next
2021-03-14 22:33:59 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:33:59 DEBUG (MainThread) [zigpy_xbee.api] Failed to enter AT command mode at 115200bps, trying 230400 next
2021-03-14 22:34:02 DEBUG (MainThread) [zigpy_xbee.api] Command mode no response to AT '+++' command
2021-03-14 22:34:02 DEBUG (MainThread) [zigpy_xbee.api] Couldn't enter AT command mode at any known baudrate.Configure XBee manually for escaped API mode ATAP2
2021-03-14 22:34:02 DEBUG (MainThread) [zigpy_xbee.api] Unsuccessful radio probe of '/dev/ttyAMA0' port
File "/usr/local/lib/python3.8/site-packages/zigpy_xbee/api.py", line 597, in _probe
await self._at_command("AP", 2)
File "/usr/local/lib/python3.8/site-packages/zigpy_xbee/api.py", line 385, in _at_partial
File "/usr/local/lib/python3.8/site-packages/zigpy_xbee/api.py", line 579, in probe
return fut.result()
File "/usr/local/lib/python3.8/site-packages/zigpy_xbee/api.py", line 600, in _probe
raise APIException("Failed to configure XBee for API mode")
zigpy.exceptions.APIException: Failed to configure XBee for API mode
2021-03-14 22:34:11 DEBUG (MainThread) [zigpy_deconz.api] Command Command.device_state (0, 0, 0)
2021-03-14 22:34:13 WARNING (MainThread) [zigpy_deconz.api] No response to 'Command.device_state' command with seq id '0x02'
2021-03-14 22:34:13 DEBUG (MainThread) [zigpy_deconz.api] Unsuccessful radio probe of '/dev/ttyAMA0' port
return fut.result()
