Hello community, I’m getting crazy with a Raspbee 2 and hassio, this is my environment:
Pi4
HassOS 3.13
HASSIO 0.110.4
From DeCONZ log:
[s6-init] making user provided files available at /var/run/s6/etc...exited 0.
[s6-init] ensuring user provided files have correct perms...exited 0.
[fix-attrs.d] applying ownership & permissions fixes...
[fix-attrs.d] done.
[cont-init.d] executing container initialization scripts...
[cont-init.d] done.
[services.d] starting services
[services.d] done.
starting version 232
[15:31:03] INFO: Waiting for device...
[15:31:03] INFO: Starting VNC server...
[15:31:06] INFO: Starting the deCONZ gateway...
libEGL warning: DRI2: failed to open swrast (search paths /usr/lib/arm-linux-gnueabihf/dri:${ORIGIN}/dri:/usr/lib/dri)
libpng warning: iCCP: known incorrect sRGB profile
[15:31:07] INFO: Starting Nginx...
[15:31:07] INFO: Running Home Assistant discovery task...
2020/06/05 15:31:07 [notice] 514#514: using the "epoll" event method
2020/06/05 15:31:07 [notice] 514#514: nginx/1.10.3
2020/06/05 15:31:07 [notice] 514#514: OS: Linux 4.19.114-v7l
2020/06/05 15:31:07 [notice] 514#514: getrlimit(RLIMIT_NOFILE): 1048576:1048576
2020/06/05 15:31:07 [notice] 514#514: start worker processes
2020/06/05 15:31:07 [notice] 514#514: start worker process 522
[15:31:07] INFO: Running the deCONZ OTA updater...
[15:31:07] INFO: Running the IKEA OTA updater...
[15:31:07] INFO: Running the LEDVANCE/OSRAM OTA updater...
[15:31:07] INFO: deCONZ is set up and running!
After a while, I got:
15:31:54:686 wait reconnect 13 seconds
15:31:55:686 failed to reconnect to network try=5
15:31:55:686 wait reconnect 12 seconds
15:31:56:686 wait reconnect 11 seconds
15:31:57:686 wait reconnect 10 seconds
15:31:58:685 wait reconnect 9 seconds
15:31:59:686 wait reconnect 8 seconds
15:32:00:685 failed to reconnect to network try=6
15:32:00:686 wait reconnect 7 seconds
15:32:01:686 wait reconnect 6 seconds
15:32:02:686 wait reconnect 5 seconds
15:32:02:724 dev /dev/ttyAMA0
15:32:03:686 wait reconnect 4 seconds
15:32:04:686 wait reconnect 3 seconds
15:32:05:686 failed to reconnect to network try=7
15:32:05:686 wait reconnect 2 seconds
15:32:06:686 wait reconnect 1 seconds
15:32:06:724 dev /dev/ttyAMA0
15:32:06:725 COM: /dev/ttyAMA0 / serialno:
15:32:06:725 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:06:743 device disconnected reason: 4, index: 0
15:32:07:686 wait reconnect 15 seconds
15:32:07:728 dev /dev/ttyAMA0
15:32:07:728 COM: /dev/ttyAMA0 / serialno:
15:32:07:728 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:08:686 wait reconnect 14 seconds
15:32:09:686 wait reconnect 13 seconds
15:32:10:686 failed to reconnect to network try=8
15:32:10:686 wait reconnect 12 seconds
15:32:11:686 wait reconnect 11 seconds
15:32:12:686 wait reconnect 10 seconds
15:32:12:725 dev /dev/ttyAMA0
15:32:13:686 wait reconnect 9 seconds
15:32:14:686 wait reconnect 8 seconds
15:32:15:686 failed to reconnect to network try=9
15:32:15:686 wait reconnect 7 seconds
15:32:16:686 wait reconnect 6 seconds
15:32:17:686 wait reconnect 5 seconds
15:32:18:685 wait reconnect 4 seconds
15:32:19:686 wait reconnect 3 seconds
15:32:20:686 failed to reconnect to network try=10
15:32:20:686 wait reconnect 2 seconds
15:32:21:686 wait reconnect 1 seconds
15:32:21:710 dev /dev/ttyAMA0
15:32:21:711 COM: /dev/ttyAMA0 / serialno:
15:32:21:711 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:21:758 device disconnected reason: 4, index: 0
15:32:22:686 wait reconnect 15 seconds
15:32:22:710 dev /dev/ttyAMA0
15:32:22:710 COM: /dev/ttyAMA0 / serialno:
15:32:22:710 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:22:737 dev /dev/ttyAMA0
15:32:23:685 wait reconnect 14 seconds
15:32:24:686 wait reconnect 13 seconds
15:32:25:686 reconnect network failed, try later
15:32:25:686 wait reconnect 12 seconds
15:32:25:686 start reconnect to network
15:32:26:686 wait reconnect 11 seconds
15:32:27:686 wait reconnect 10 seconds
15:32:28:686 wait reconnect 9 seconds
15:32:29:686 wait reconnect 8 seconds
15:32:30:686 failed to reconnect to network try=1
15:32:30:686 wait reconnect 7 seconds
15:32:31:686 wait reconnect 6 seconds
15:32:32:686 wait reconnect 5 seconds
15:32:32:726 dev /dev/ttyAMA0
15:32:33:686 wait reconnect 4 seconds
15:32:34:686 wait reconnect 3 seconds
15:32:35:685 failed to reconnect to network try=2
15:32:35:686 wait reconnect 2 seconds
15:32:36:685 wait reconnect 1 seconds
15:32:36:723 dev /dev/ttyAMA0
15:32:36:723 COM: /dev/ttyAMA0 / serialno:
15:32:36:723 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:36:757 device disconnected reason: 4, index: 0
15:32:37:686 wait reconnect 15 seconds
15:32:37:724 dev /dev/ttyAMA0
15:32:37:724 COM: /dev/ttyAMA0 / serialno:
15:32:37:724 COM: --dev: /dev/ttyAMA0 (RaspBee)
15:32:38:687 wait reconnect 14 seconds
15:32:39:686 wait reconnect 13 seconds
15:32:40:686 failed to reconnect to network try=3
15:32:40:686 wait reconnect 12 seconds
15:32:41:686 wait reconnect 11 seconds
15:32:42:686 wait reconnect 10 seconds
15:32:42:724 dev /dev/ttyAMA0
15:32:43:686 wait reconnect 9 seconds
15:32:44:685 wait reconnect 8 seconds
15:32:45:686 failed to reconnect to network try=4
15:32:45:686 wait reconnect 7 seconds
15:32:46:686 wait reconnect 6 seconds
15:32:47:686 wait reconnect 5 seconds
15:32:48:685 wait reconnect 4 seconds
15:32:49:685 wait reconnect 3 seconds
15:32:50:686 failed to reconnect to network try=5
15:32:50:686 wait reconnect 2 seconds
15:32:51:686 wait reconnect 1 seconds
15:32:51:725 dev /dev/ttyAMA0
15:32:51:725 COM: /dev/ttyAMA0 / serialno:
15:32:51:725 COM: --dev: /dev/ttyAMA0 (RaspBee)
And from Phoscon App I got Not Connected
Could someone help me to solve this issue? Thank you
