Hi, I just put an Raspbee II module (not USB) into my Raspberry Pi 4 with Home Assistant OS. I installed “deCONZ” over the Add-On Store, but in Phoscon the Gateway keeps “Firmware: Not Connected”.
So I did a firmware upgrade by using a second SD Card with the deconz image and this guide:
The deconz image for raspberry works well. It shows the firmware version 26-72-0700 and I can connect Zigbee Devices without any problems. But when I put the home assistant SD card back into my Raspberry Pi it keeps “Firmware: Not Connected”.
Is there any solution?
