Hello community,
I’m new to the home assistent topic, I have a raspberry pi 3b and a raspbee ii connected to it. To “activate” the raspbee I already configurable the config.txt with the following :
enable_uart=1
dtoverlay=pi3-miniuart-bt
Now I can configure the plugin DeConz without any problems. But I want to use ZHA. When I tried to use the integration ZHA (after deinstalling DeConz), he always gives me an error.
My steps:
- Search for the ZHA integration
- Select the serial path /dev/ttyAMA0 - ttyAMA0
- Manually select protocol deCONZ = dresden elektronik deCONZ protocol: ConBee I/II, RaspBee I/II
- Check all infos and press submit
Then I get a red message: Connection failed.
I already tried to use the long serial path from the hardware settings but same error
I hope someone can help me
Jeremy
