RaspBee II installation trouble
I am using HA (HA OS) and would like to use RapBee II from Elektrotechnik Dresden.
As I found out it is even less plug and play as e.g. Sonoff Zigbee Sticks. :wink:
I found a way to find the config.txt and get that edited (I mounted it in windows using the paragon file system reader for linux).
I have added
enable_uart=1
dtparam=i2c_arm=on
dtparam=i2c_vc=on
dtoverlay=miniuart-bt
dtoverlay=i2c-rtc,pcf85063
at the end of the file and start the PI again. Then I hoped to find the raspbee II under the hardware section within HA (similarly as a Sonoff Stick for example).
a) In which section under Hardware should I look to see the RaspBee II?
b) Anybody any idea what else to be done? Any Idea what I did miss to make ist work (later using zigbee2mqtt)
Thanks a lot,
Tom
Hey, nobody any idea? At least where I should look for within the hardware section if HA, if the RasBee II has been recognised correctly?
Thanks & regards
DEVLINKS: /dev/serial0
DEVNAME: /dev/ttyAMA0
DEVPATH: /devices/platform/soc/fe201000.serial/tty/ttyAMA0
MAJOR: β€˜204’
MINOR: β€˜64’
SUBSYSTEM: tty
TAGS: β€˜:systemd:’
USEC_INITIALIZED: β€˜2713766’
