I am since a few days fighting with getting an installation up and running. I have restarted a number of times, tried two different SD cards and the problem remains.
Basically what I do is
LDownload the raspbian jessie lite 2016-09-23. Apparently after this one can not SSH into a fresh installed raspbian installation. I guess it is safe, but then you need to connect a keyboard and display. Not a wise decision IMHO.
Using Win32Diskimager creating drive for the Raspi
SSH into the raspi using putty
Download the latest updates with sudo apt-get update && sudo apt-get upgrade -y
sudo raspi-config to change the time zone and location.
Since there is a new kernel, sudo reboot and login again.
when the installation crashes I do
rm -rf fabric-home-assistant
sudo apt-get install libffi-dev libssl-dev
sudo pip install cryptography --force-reinstall
at some point I am getting a message that the system goes down for a reboot.
I have tried to run a tail -f /var/log messages or syslog and I am not getting anything useful to what could be causing the crash.
I have read that others have followed the procedure above and that it should work.
I wish it had been that simple. After doing the above I get further, but then at some point it just decides to reboot.
Its not that the installation stops, the raspberry reboots.
Here is what I have in the log file
Dec 18 21:28:46 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 21:29:46 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 21:28:57 raspberrypi systemd[1]: Reloading.
Dec 18 21:29:00 raspberrypi systemd[1]: Reloading.
Dec 18 21:29:00 raspberrypi systemd[1]: Starting LSB: mosquitto MQTT v3.1 message broker…
Dec 18 21:29:00 raspberrypi mosquitto[30946]: Starting network daemon:: mosquitto.
Dec 18 21:29:00 raspberrypi systemd[1]: Started LSB: mosquitto MQTT v3.1 message broker.
Dec 18 21:29:01 raspberrypi systemd[1]: Reloading.
Dec 18 21:30:56 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 21:31:56 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 21:31:00 raspberrypi systemd[1]: Reloading.
Dec 18 21:44:52 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 21:45:52 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 21:56:07 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 21:57:07 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 22:06:25 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 22:07:25 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 22:07:25 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 22:08:25 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 22:08:57 raspberrypi rsyslogd-2007: action ‘action 17’ suspended, next retry is Sun Dec 18 22:09:57 2016 [try http://www.rsyslog.com/e/2007 ]
Dec 18 22:08:58 raspberrypi rsyslogd: [origin software=“rsyslogd” swVersion=“8.4.2” x-pid=“485” x-info=“http://www.rsyslog.com”] exiting on signal 15.
Broadcast message from pi@raspberrypi on pts/3 (Sun 2016-12-18 22:09:01 UTC):
I have tried two different SD cards, and it is the same… I don’t think it is the SD card. I have tried the jessie lite, full installation, with or without sudo dist-get update/upgrade…
It is not working for me, and I don’t file any leads to why it reboots. That is to me also odd, it is a message that it needs to reboot, so it is not a full blown crash. It is somehow a controlled reboot
These are the commands I used to get Home Assistant up and running using a clean install of Jessie (Pixel). Once the Jessie image has deployed to SD card, boot up into the UI enable SSH, set password and hostname then reboot. Connect using Putty or some other SSH tool, I have also used Juice on android too.
Once the installation is complete you will need to fix the mqtt broker error in configuration.yaml (home/hass/.homeassistant/configuration,yaml) there is normally a duplicate that you will need to delete and then setup the original mqtt broker to either point to your local host IP or change it to a cloud mqtt broker.
Once you fixed the mqtt broker you can restart the Home Assistant service using the following command
