Hello HomeAssistant Community.
I bought a Raspberry Pi 3 A+ today and I installed a homeassistant os the latest version
and shortly after it boot and I can enter the server from the IP address it stops suddenly and I can’t restart using the command line in the homeassistant os on the RP so it stops even the RP so I had to unplug the power and plug it again and it boots normally again and stops shortly after booting
and this issue happens when I download an add-on (SSH-Terminal)
and I bought the SD card that I used in the RP since 2015 so I don’t know where is the problem is it from the SD card or the add-ons
and my Home Assistant server on my laptop was working perfectly and without any issue
Thanks all for the replay and I hope you help me fix this issue.
it shows me this command line in the RP HA command line
ha > [ 615.345030] INFO: task kworker/2:0:26 blocked for more than 122 seconds
[ 615.348962] Tainted: G C 5.15.84-v8 #1
[ 615.352727] “echo 0 > /proc/sys/kernel/hung_task_timeout_secs” disables this message.
and it keeps showing this command line but with different numbers
Edited: the problem also happens without starting the add-on ( SSH-Terminal )
