Hi
Here is my full Arduino code. It is used on a nodemcu that controls my heaters (infrared) livolo light switches (433mhz) and Energenie switches (443mhz) it also has temperature and light sensors on it. it is all controlled by visiting a page eg 192.168.1.91/bulb1 will turn on one of my livolo lights. I have one of these devices in each room collecting temperature and light data. As well as controlling my environment.
Michael
#include <WiFiClient.h>
#include <ESP8266WebServer.h>
#include "DHT.h"
#include <livolo.h>
#include <RCSwitch.h>
#include <OneWire.h>
#include <DallasTemperature.h>
#include <IRremoteESP8266.h>
RCSwitch mySwitch = RCSwitch();
IRsend irsend(13);
unsigned int raw[277] = {9864,948,492,904,496,908,496,908,496,916,488,916,1188,1620,484,912,496,904,492,912,492,912,496,912,492,912,492,916,1168,1012,404,1000,416,1620,480,908,492,912,496,916,488,924,1192,996,404,1620,480,904,488,920,496,916,488,912,488,924,1184,1620,1188,1600,504,908,496,912,492,920,480,912,1196,1600,1212,1600,496,924,484,908,496,904,1180,1024,404,1000,404,1604,500,900,488,920,1200,1604,500,904,1204,1604,1204,1616,488,904,500,904,1184,1620,1208,1616,480,908,500,908,496,908,496,904,1204,1616,472,920,500,904,1200,984,392,1012,420,984,420,984,420,988,404,996,420,992,400,992,424,984,420,980,408,1012,404,984,420,988,420,980,412,992,420,984,420,1000,404,984,420,980,420,984,420,988,416,988,416,1000,404,988,416,984,420,984,420,984,428,976,416,988,416,988,416,988,416,984,416,988,420,984,420,984,416,992,416,984,416,988,424,980,400,1004,416,988,400,1004,416,984,424,980,420,984,404,1000,420,984,420,984,400,1004,420,984,416,988,420,980,424,980,424,980,424,980,420,988,416,984,420,984,416,988,416,988,404,1004,412,988,400,1004,412,992,412,1628,472,928,476,924,1180,1636,468,936,464,940,464,936,468,940,1168,1640,460,940,464,944,460,944,460,940,460,944,1144,1044,384,};
unsigned int raw2[277] = {9896,916,496,908,496,908,480,920,496,912,492,908,1192,1632,480,908,496,908,492,924,480,916,488,912,464,936,468,940,1168,1028,400,1004,404,1624,480,912,488,924,480,924,460,932,1196,996,404,1624,480,912,468,948,480,924,452,952,480,924,1176,1632,1184,1608,492,924,484,908,492,908,496,912,488,912,492,924,480,928,480,920,480,912,492,908,496,908,1172,1652,1184,1600,500,904,472,936,1200,1604,1204,980,420,1608,496,908,496,912,492,912,492,924,480,908,492,912,1196,1604,500,908,500,904,496,904,1200,1612,496,908,496,904,1176,1632,1200,984,388,1020,416,988,412,1004,400,984,420,988,420,980,420,992,412,992,412,988,416,984,420,980,424,980,424,984,416,992,412,988,416,988,416,984,396,1008,420,980,424,988,412,988,388,1016,412,988,420,984,420,984,420,988,416,984,416,984,396,1008,392,1012,420,984,400,1008,416,984,392,1012,420,980,420,984,420,984,420,984,420,988,416,984,396,1004,420,988,416,988,416,988,416,988,416,984,416,988,420,984,420,984,420,988,416,984,420,984,408,1000,416,984,416,988,408,992,420,1004,396,1000,404,996,408,992,408,996,408,1008,368,1032,396,1632,1176,1632,1172,1632,472,936,1168,1016,388,1636,464,940,464,936,1168,1644,1164,1020,360,1044,384,1020,384,};
Livolo livolo(4); // transmitter connected to pin #4
#define ONE_WIRE_BUS 5
#define WLAN_SSID "put your SSID here"
#define WLAN_PASS "put your password her"
ESP8266WebServer server(80);
OneWire oneWire(ONE_WIRE_BUS);
DallasTemperature sensors(&oneWire);
float temp_c, light, temp_c2;
int lightPin = A0; //define a pin for Photo resistor
void ReadSensor() {
sensors.requestTemperatures();
// Read temperature as Celsius
temp_c = sensors.getTempCByIndex(0)- 2;
temp_c2 = sensors.getTempCByIndex(1)- 2;
light = analogRead(lightPin)/2;
// Check if any reads failed and exit early (to try again).
if isnan(temp_c) {
Serial.println("Failed to read from DHT sensor :-(");
return;
void setup() {
irsend.begin();
Serial.begin(115200);
delay(10);
mySwitch.enableTransmit(4);
// Connecting to wifi
WiFi.begin(WLAN_SSID, WLAN_PASS);
// Set a static IP (optional)
IPAddress ip(192, 168, 1, 91);
IPAddress gateway(192, 168, 1, 1);
IPAddress subnet(255, 255, 255, 0);
WiFi.config(ip, gateway, subnet);
while (WiFi.status() != WL_CONNECTED) {
delay(500);
Serial.print(".");
Serial.println("");
Serial.print("Connected to wifi with IP ");
Serial.println(WiFi.localIP());
// Define capabilities of our little web server
server.on("/heaton", [](){
irsend.sendRaw(raw,277,38);
delay(2000);
server.send(200, "text/plain", "Heater On");
server.on("/heatoff", [](){
irsend.sendRaw(raw2,277,38);
delay(2000);
server.send(200, "text/plain", "Heater Off");
server.on("/temp_c2", [](){
ReadSensor();
server.send(200, "text/plain", String(temp_c2));
server.on("/temp_c", [](){
ReadSensor();
server.send(200, "text/plain", String(temp_c));
server.on("/light", [](){
ReadSensor();
server.send(200, "text/plain", String(light));
server.on("/bulb1", [](){
livolo.sendButton(6550, 120);
server.send(200, "text/plain", "Livingroom 1 light On");
server.on("/bulb2", [](){
livolo.sendButton(6550, 106);
server.send(200, "text/plain", "Livingroom 1 light Off");
server.on("/bulb3", [](){
livolo.sendButton(7400, 120);
server.send(200, "text/plain", "Livingroom 2 light On");
server.on("/bulb4", [](){
livolo.sendButton(7400, 106);
server.send(200, "text/plain", "Livingroom 2 light Off");
server.on("/bulb5", [](){
livolo.sendButton(8500, 120);
server.send(200, "text/plain", "Kitchen light on");
server.on("/bulb6", [](){
livolo.sendButton(8500, 106);
server.send(200, "text/plain", "Kitchen light off");
server.on("/bulb7", [](){
livolo.sendButton(19303, 120);
server.send(200, "text/plain", "Bedroom light on");
server.on("/bulb8", [](){
livolo.sendButton(19303, 106);
server.send(200, "text/plain", "Bedroom light off");
server.on("/bulb9", [](){
livolo.sendButton(10550, 120);
server.send(200, "text/plain", "Spare Bedroom light on");
server.on("/bulb10", [](){
livolo.sendButton(10550, 106);
server.send(200, "text/plain", "Spare Bedroom light off");
server.on("/bulb11", [](){
livolo.sendButton(6400, 106);
server.send(200, "text/plain", "All lights off");
server.on("/energenie1on", [](){
mySwitch.send(5122515, 24);
server.send(200, "text/plain", "Lights on");
server.on("/energenie1off", [](){
mySwitch.send(5122514, 24);
server.send(200, "text/plain", "Lights off");
server.on("/energenie2on", [](){
mySwitch.send(5122507, 24);
server.on("/energenie2off", [](){
mySwitch.send(5122506, 24);
server.on("/energenie3on", [](){
mySwitch.send(5122511, 24);
server.on("/energenie3off", [](){
mySwitch.send(5122510, 24);
server.on("/energenie4on", [](){
mySwitch.send(5122503, 24);
server.on("/energenie4off", [](){
mySwitch.send(5122502, 24);
server.on("/energenieallon", [](){
mySwitch.send(5122513, 24);
server.on("/energeniealloff", [](){
mySwitch.send(5122512, 24);
server.on("/energenielivon", [](){
mySwitch.send(5122591, 24);
server.on("/energenielivoff", [](){
mySwitch.send(5122590, 24);
server.on("/energeniebedon", [](){
mySwitch.send(5122583, 24);
server.on("/energeniebedoff", [](){
mySwitch.send(5122582, 24);
server.on("/energeniebathon", [](){
mySwitch.send(5122587, 24);
server.on("/energeniebathoff", [](){
mySwitch.send(5122586, 24);
server.on("/", [](){
server.send(200, "text/plain", "McArthur Home Automation - /heaton /heatoff /temp_c /bulb1 /bulb2 /bulb3 /bulb4 /bulb5 /bulb6 /energenie1on /energenie1off /energenie2on /energenie2off /energenie3on /energenie3off /energenie4on /energenie4off /energenieallon /energeniealloff /energenielivon /energenielivoff /energeniebedon /energeniebedoff ");
server.begin();
Serial.println("HTTP server started");
sensors.begin();
void handle_root() {
server.send(200, "text/plain", "All systems go. Read data from /temp or or /temp_c or /humidity or /heatindex.");
delay(100);
void loop() {
server.handleClient();
