I am new to this forum and have already some questions…
1. I would like to update the firmware for my raspi.
I tried it this way:
curl -L --output /usr/bin/rpi-update rpi-update && chmod +x /usr/bin/rpi-update
apk add binutils
rpi-update
*** Raspberry Pi firmware updater by Hexxeh, enhanced by AndrewS and Dom
*** Performing self-update
*** Relaunching after update
!!! /boot doesn't exist - creating
!!! //lib/modules doesn't exist - creating
*** We're running for the first time
*** Backing up files (this will take a few minutes)
*** Backing up firmware
*** Backing up modules 4.14.66-v7
date: invalid date ''
date: invalid date '2018-02-09T18:54:08Z'
date: invalid date '2018-09-05T16:45:43Z'
This update bumps to rpi-4.14.y linux tree
Be aware there could be compatibility issues with some drivers
Discussion here:
https://www.raspberrypi.org/forums/viewtopic.php?f=29&t=197689
*** Downloading specific firmware revision (this will take a few minutes)
% Total % Received % Xferd Average Speed Time Time Time Current
Dload Upload Total Spent Left Speed
100 168 0 168 0 0 227 0 --:--:-- --:--:-- --:--:-- 227
100 56.0M 100 56.0M 0 0 1207k 0 0:00:47 0:00:47 --:--:-- 1500k
*** Updating firmware
*** Updating kernel modules
*** depmod 4.14.68-v7+
*** depmod 4.14.68+
*** Updating VideoCore libraries
*** Using HardFP libraries
*** Updating SDK
*** Running ldconfig
It looks like the update does not work, because running the same command again shows the same output…
2. updating the system:
core-ssh:~# apk update
core-ssh:~# apk upgrade
(1/11) Upgrading busybox (1.27.2-r8 -> 1.27.2-r11)
Executing busybox-1.27.2-r11.post-upgrade
(2/11) Upgrading libressl2.6-libcrypto (2.6.3-r0 -> 2.6.5-r0)
(3/11) Upgrading libressl2.6-libssl (2.6.3-r0 -> 2.6.5-r0)
(4/11) Installing libressl2.6-libtls (2.6.5-r0)
(5/11) Installing ssl_client (1.27.2-r11)
(6/11) Upgrading ncurses-terminfo-base (6.0_p20171125-r0 -> 6.0_p20171125-r1)
(7/11) Upgrading ncurses-terminfo (6.0_p20171125-r0 -> 6.0_p20171125-r1)
(8/11) Upgrading ncurses-libs (6.0_p20171125-r0 -> 6.0_p20171125-r1)
(9/11) Upgrading libcurl (7.60.0-r1 -> 7.61.0-r0)
(10/11) Upgrading curl (7.60.0-r1 -> 7.61.0-r0)
(11/11) Upgrading jq (1.5-r4 -> 1.5-r5)
Executing busybox-1.27.2-r11.trigger
Executing ca-certificates-20171114-r0.trigger
OK: 63 MiB in 47 packages
After rebooting my raspi, the updates are removed… (same output as above)
3. I saw, that hass.io runs under Alpine Linux 3.7.
Is it recommended to update to 3.8 (if it is possible)?
The changelog says: “Add support for Raspberry Pi 3 Model B+”
What does this mean, I am already running on this model…
(I assume the idea behind hass.io is, that the system cannot/shouldnot be updated by users by themself…)
Thx for clarification…
