it seems that code.c is causing the problem, tho’ what the problem is I have no idea
I am just wondering if anyone tried the AIO install recently and if they had any luck.
I have tried 3 times today and getting stuck at the same place all the time.  I have to say that I’m a little bit disappointed  and was hoping to have something to play with this evening and test this out.
Here’s where it stops:
[localhost] out: /srv/hass/src/open-zwave-control-panel/webserver.cpp:338: warning: the use of mktemp' is dangerous, better use mkstemp’ or `mkdtemp’
[localhost] out:
Connection to 192.168.XXX.XXX closed by remote host.
So if AIO is not working, can someone with more experience recommend the next best install method? The manual install or the RPi image? Thanks
If you’re having trouble with the AiO method I suggest checking out the Hassbian image.
