Hey,
I am using home assistant on raspberry pi 4 with docker long time.
When i see rhasspy local voice app, i challenging audio with raspberry. but only see in the list ’ Dummy Output ’
I read a lot of topics and comments from sites, then i realize, docker cant use host(raspberry pi) onboard audio.
I found code for solution (i think its solution)
docker run -it --rm --device /dev/snd:/dev/snd
I couldnt success with it because i havent enough information with commands.
This is my configuration;
Sürüm core-2023.3.2
Kurulum Türü Home Assistant Supervised
Geliştirme false
Süpervizör true
Docker true
Kullanıcı root
Sanal Ortam false
Python Sürümü 3.10.10
İşletim Sistemi Ailesi Linux
İşletim Sistemi Sürümü 5.15.84-v8+
CPU Mimarisi aarch64
Saat dilimi Europe/Istanbul
Yapılandırma Dizini /config
Audio logs;
s6-rc: info: service s6rc-oneshot-runner: starting
s6-rc: info: service s6rc-oneshot-runner successfully started
s6-rc: info: service fix-attrs: starting
s6-rc: info: service fix-attrs successfully started
s6-rc: info: service legacy-cont-init: starting
cont-init: info: running /etc/cont-init.d/alsa-mixer.sh
[02:53:14] INFO: Adjust ALSA mixer settings for /dev/snd/controlC0
[02:53:14] INFO: Adjust ALSA mixer settings for /dev/snd/controlC1
[02:53:15] INFO: Adjust ALSA mixer settings for /dev/snd/controlC2
cont-init: info: /etc/cont-init.d/alsa-mixer.sh exited 0
cont-init: info: running /etc/cont-init.d/filesystem.sh
cont-init: info: /etc/cont-init.d/filesystem.sh exited 0
cont-init: info: running /etc/cont-init.d/pulse-config.sh
[02:53:15] INFO: Found RaspberryPi system
cont-init: info: /etc/cont-init.d/pulse-config.sh exited 0
s6-rc: info: service legacy-cont-init successfully started
s6-rc: info: service legacy-services: starting
services-up: info: copying legacy longrun alsa (no readiness notification)
services-up: info: copying legacy longrun pulseaudio (no readiness notification)
s6-rc: info: service legacy-services successfully started
W: [pulseaudio] main.c: Running in system mode, but --disallow-module-loading not set.
W: [pulseaudio] main.c: Home directory of user 'root' is not '/var/run/pulse', ignoring.
W: [pulseaudio] caps.c: Normally all extra capabilities would be dropped now, but that's impossible because PulseAudio was built without capabilities support.
W: [pulseaudio] main.c: OK, so you are running PA in system mode. Please make sure that you actually do want to do that.
W: [pulseaudio] main.c: Please read http://www.freedesktop.org/wiki/Software/PulseAudio/Documentation/User/WhatIsWrongWithSystemWide/ for an explanation why system mode is usually a bad idea.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card0: No such file or directory
E: [pulseaudio] module-alsa-card.c: Failed to find a working profile.
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="0" name="platform-bcm2835_audio" card_name="alsa_card.platform-bcm2835_audio" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card1: No such file or directory
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="1" name="platform-fef00700.hdmi" card_name="alsa_card.platform-fef00700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
W: [pulseaudio] module-udev-detect.c: Failed to open /proc/asound/card2: No such file or directory
E: [pulseaudio] module.c: Failed to load module "module-alsa-card" (argument: "device_id="2" name="platform-fef05700.hdmi" card_name="alsa_card.platform-fef05700.hdmi" namereg_fail=false tsched=no fixed_latency_range=no ignore_dB=no deferred_volume=yes use_ucm=yes avoid_resampling=no card_properties="module-udev-detect.discovered=1""): initialization failed.
E: [pulseaudio] module-rescue-streams.c: module-rescue-stream is obsolete and should no longer be loaded. Please remove it from your configuration.
E: [pulseaudio] main.c: Failed to acquire org.pulseaudio.Server: org.freedesktop.DBus.Error.AccessDenied: Connection ":1.53" is not allowed to own the service "org.pulseaudio.Server" due to security policies in the configuration file
Sorry for my bad english, trying get help with sound.
Any help would be appreciated.
