I am posting this here in case anyone has a similar issue and/or it helps anyone else.
System configuration:
2GB Raspberry Pi 4B
OEM Power Supply
Buster 10.0 (7/10/19)
Docker CE nightly 0.0.0-20190723010156-67a3bd4
Home Assistant 0.96.4 on Docker
Aeon Labs Gen5 USB Zstick (no network key or secure nodes)
Generic USB hub (to work around the issue with proper device detection of the ZStick)
Problem Description:
An initial installation of HA on an RPi 4B with a ~25 node ZW configuration starts and works nominally. There are no dead nodes, all nodes respond and operate. Over a two-day period there are no dead or inoperable nodes, and no notable errors in the OZW.log
Diagnostic Info:
The OZW.log file for Node031 reports this for SwitchAllCmd_Get:
2019-07-26 13:46:14.960 Info, Node031, Sending (Query) message (Callback ID=0xa4, Expected Reply=0x04) - SwitchAllCmd_Get (Node=31): 0x01, 0x09, 0x00, 0x13, 0x1f, 0x02, 0x27, 0x02, 0x25, 0xa4, 0x5c
2019-07-26 13:46:14.968 Detail, Node031, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-26 13:46:14.968 Detail, Node031, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-26 13:46:15.087 Detail, Node031, Received: 0x01, 0x07, 0x00, 0x13, 0xa4, 0x00, 0x00, 0x0d, 0x42
2019-07-26 13:46:15.087 Detail, Node031, ZW_SEND_DATA Request with callback ID 0xa4 received (expected 0xa4)
2019-07-26 13:46:15.087 Info, Node031, Request RTT 127 Average Request RTT 143
2019-07-26 13:46:15.087 Detail, Expected callbackId was received
2019-07-26 13:46:15.134 Detail, Node031, Received: 0x01, 0x09, 0x00, 0x04, 0x00, 0x1f, 0x03, 0x27, 0x03, 0xff, 0x35
2019-07-26 13:46:15.135 Detail,
2019-07-26 13:46:15.135 Info, Node031, Response RTT 175 Average Response RTT 204
2019-07-26 13:46:15.135 Detail, Node031, Initial read of value
2019-07-26 13:46:15.135 Info, Node031, Received SwitchAll report from node 31: On and Off Enabled
2019-07-26 13:46:15.135 Detail, Node031, Expected reply and command class was received
2019-07-26 13:46:15.135 Detail, Node031, Message transaction complete
Issue:
After a restart of the RPi 4B (without configuration changes) one or two dead nodes appear, and the OZW.log reports:
2019-07-26 14:54:06.607 Info, Node031, Sending (Query) message (Callback ID=0xa5, Expected Reply=0x04) - SwitchAllCmd_Get (Node=31): 0x01, 0x09, 0x00, 0x13, 0x1f, 0x02, 0x27, 0x02, 0x25, 0xa5, 0x5d
2019-07-26 14:54:06.731 Detail, Node031, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-26 14:54:06.731 Detail, Node031, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-26 14:54:12.241 Detail, Node031, Received: 0x01, 0x07, 0x00, 0x13, 0xa5, 0x01, 0x02, 0x34, 0x79
2019-07-26 14:54:12.241 Detail, Node031, ZW_SEND_DATA Request with callback ID 0xa5 received (expected 0xa5)
2019-07-26 14:54:12.242 Info, Node031, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-07-26 14:54:12.242 Warning, Node031, WARNING: Device is not a sleeping node.
2019-07-26 14:54:12.242 Detail, Node001, Expected callbackId was received
2019-07-26 14:54:14.606 Error, Node031, ERROR: Dropping command, expected response not received after 1 attempt(s)
2019-07-26 14:54:14.606 Detail, Node031, Removing current message
2019-07-26 14:54:14.607 Detail, Node031, Notification: Notification - TimeOut
2019-07-26 14:54:14.614 Info, Node031, Sending (Send) message (Callback ID=0xde, Expected Reply=0x04) - SwitchBinaryCmd_Get (Node=31): 0x01, 0x09, 0x00, 0x13, 0x1f, 0x02, 0x25, 0x02, 0x25, 0xde, 0x24
2019-07-26 14:54:14.743 Detail, Node031, Received: 0x01, 0x04, 0x01, 0x13, 0x01, 0xe8
2019-07-26 14:54:14.744 Detail, Node031, ZW_SEND_DATA delivered to Z-Wave stack
2019-07-26 14:54:19.979 Detail, Node031, Received: 0x01, 0x07, 0x00, 0x13, 0xde, 0x01, 0x02, 0x18, 0x2e
2019-07-26 14:54:19.979 Detail, Node031, ZW_SEND_DATA Request with callback ID 0xde received (expected 0xde)
2019-07-26 14:54:19.979 Info, Node031, WARNING: ZW_SEND_DATA failed. No ACK received - device may be asleep.
2019-07-26 14:54:19.979 Warning, Node031, WARNING: Device is not a sleeping node.
2019-07-26 14:54:19.979 Error, Node031, ERROR: node presumed dead
2019-07-26 14:54:19.979 Warning, CheckCompletedNodeQueries m_allNodesQueried=0 m_awakeNodesQueried=0
2019-07-26 14:54:19.979 Warning, CheckCompletedNodeQueries all=0, deadFound=1 sleepingOnly=0
2019-07-26 14:54:19.979 Detail, Node001, Expected callbackId was received
2019-07-26 14:54:19.979 Detail, Node031, Notification: Notification - Node Dead
A second restart increase the number of dead nodes from one to four or more. It does not matter if you reboot the RPi 4B in between HA restarts, the same scenario is repeatable.
Resolution:
At this point removing the Zstick and installing it in an RPi 3B+ with the same (prior to the problem) /config directory works correctly across restarts with no dead nodes. Subsequently, moving the Zstick BACK to the RPi 4B, rebooting and restarting the RPi 4B removes the dead nodes and HA works normally until the first restart, when the dead nodes reappear. This scenario is also repeatable, although I have not noticed whether there is any similarity in which nodes fail upon each restart.
If anyone comes across this topic and has similar issues it might help identify the root cause of the problem.
UPDATE - Edited 07-27-2019:
After thinking about the differences between the Rpi 3B+ and the Rpi 4B it occurred to me that the Rpi 3B+ was in a slightly different location (a few feet away) from the Rpi 4B. So I swapped the locations and voilà, the dead node issues with the Rpi 4B went away. Noteably, the Rpi 3B+ continued to work as well. So I swapped the locations back and was able to replicate the dead nodes on the Rpi 4B in the original location. It 'tis a mystery what is different between the two locations other than a few feet of distance.
