Raspberry pi 4 boot from usb for hassio
Hi
I successfully upgrade mi pi 4 to the last stable eeprom that allowed boot from usb
I ended capable to boot from usb when I installed raspberry pi os, but when I try to burn the hassio Image on the USB , I cannot boot and do not receive ping from the device
Please help
Regards
David
Hi David, I am in the same situation like you.
did you have any update on this?
Hi
Yes. And very good news
I try to install the home assistant directly on the pi with a full pi OS and it is working great an stable and most important fast fast !!
I am not Linux familiar but I did exactly all the commands line at the attached link and I am very happy :smiley:
Now I can also access with SSH and RDP to the pi
Regards
David
Installing Home Assistant Supervised on Raspberry Pi OS
course all the above is with USB stick attached to the pi 4 without any SD card
