Does anyone know a detailed installing process of hassio on raspberry pi 4. Want to install it headless. I used Ethernet and it didn’t work. It showed up on router page but didn’t have a time, tx and rx data rate. When I tried to use wifi to connect with the USB, that also didn’t connect. Anyone knows what to do ?
On the router, do you seen the ip address of the pi 4? If so, use that address and port 8134, e.g. http://192.168.1.111:8123
Thanks. It started working
Having the same problem and 8123 solved it!
Super thanks a lot!,
