Raspberry Pi 4 RTC
I have a relatively simple HA (just a few automations for now) running on a Raspberry Pi 4. After reading about SD card issues, I now have the Pi booting from an NVMe/USB.
So far, so good except for a nagging problem. Every time I have to reboot the Pi I have to manually reset the correct date and time. The Pi has no RTC with battery to preserve the time/date settings between boots.
There are add-on RTC boards for the Pi but I’m wondering if it’s worth it as I will eventually have to migrate to something bigger anyway.
Has anyone else found a solution for this issue?
HAOS tries to set the time using an NTP server. You should not need to manually set the time unless NTP is being blocked or not available.
  1. The cheap RTC boards don’t just work.
    Many are a DS3231 and need to be setup both on the kernel boot config.txt, and read / written with a privileged command.
    This might work if you run custom Debian with containers, but not with the deliberately locked-down HAOS.
  1. As MaxK just posted - wait 10 seconds after boot and the clock will be set from a remote Internet time server via NTP, so there’s no point (unless you’ve got no access…).
Unlike the RPi4, the RPi5 has a hardware RTC and supports battery backup, but I only added the cell as it’s £4 and a novelty. I found the DS3231 modules weren’t worth the hassle of setup, and maintaining changes to scripts across upgrades was more trouble than they’re worth.
The only use I found was fractionally improving lock times with a GPSr on a boat navigation device - and later GPSr include battery-backed RTC and ephemeris anyway.
When they announced the Yellow, based on a Pi 4 compute module and having a RTC, I hoped they would add support for a RTC on regular PI’s. But they did not.
Thanks for the info. I won’t waste my time or money on upgrading the Pi.
BTW, I did manage to get NTP working on the Pi, as described in another post.
