Raspberry Pi 4 Supported
Hi
Should I reflash my SD card with the latest version of Hassos now that its supports Pi 4
Merry Christmas :grinning:
I assume you are using hass.io. Than it’s no need for reflash your SD card.
You can update the OS on the Web-UI --> Sidebar-Menu --> Hass.io --> System --> Host system --> update
that’s it.
Actual version is HassOS 3.7 (do a snapshot-backup to your local device before updating)
Thank you Merry Christmas to you
That was a great help thank you
@honikos Merry Christmas !
I’m on Home Assistant 0.103.3 but my System --> Host system does not show anything regarding the hostname & version.
How do I know for sure I have the right OS? Thanks
hmmm, can you post the information from sidebar developer-tools --> Info ?
You can also update your installation to hass.io 103.4 (hass.io --> dashboard)
