Raspberry Pi 5 - Charging the RTC-Battery?
I have the official RTC-Battery for the Raspberry PI 5. On the Raspberry Pi OS you can config that the battery is charged while your pi is running, is this also possible on HA?
HASS runs as a virtual machine running on an isolated HAOS kernel. I’d doubt the supervisor exposes the underlying hardware status.
On the other hand, my RPi5 with a battery just works. Although RPiOS (what was Raspian) might have better support for power management, “it just works” via firmware.
The easiest test is to disconnect the network (so no NTP), shutdown, wait, and restart HAOS and see if the time is correct.
Isn’t that the problem, it won’t progress through a startup if it doesn’t get the time in this case from the rtc.
On Raspbian or HAOS? Never seen a boot stop due to bad time on a RPi.
The OS either takes the time from the last filesystem timestamp (which could be years ago, but better than marking files in the past, or NTP.
The RPi5 is the first Pi to have a RTC so it is integrated in the firmware (unlike add-on RTC you may know of like a rtc-ds1307 which need manual scripting).
So it looks like a charging like with RPiOS is not possible, sadly if I understand this right?
It should “just work” via the RPi5 firmware.
See my previous post for how to check.
You can check the voltage and charging voltage with these commands
cat /sys/devices/platform/soc/soc:rpi_rtc/rtc/rtc0/battery_voltage
cat /sys/devices/platform/soc/soc:rpi_rtc/rtc/rtc0/charging_voltage
FYI, these are the steps I took to enable the external RTC battery charging on the haos_rpi5-64-13.1 image
  1. Connected the SD card to my Linux laptop
  2. mkdir boot
  3. sudo mount /dev/sda1 boot
  4. sudo vi boot/config.txt (or use nano, notepad, whatever you want. Just make sure to have root permissions)
  5. Added the following line to the file
    dtparam=rtc_bbat_vchg=3000000
    (that’s a total of six 0s)
  6. sync
  7. sudo umount boot
  8. Make sure any other drives that were auto-mounted are unmounted, and safely remove the SD card from the laptop
  9. Put back into Pi, powered up, and verified charging voltage was set
[core-ssh ~]$ cat /sys/devices/platform/soc/soc\:rpi_rtc/rtc/rtc0/charging_voltage
3000000
[core-ssh ~]$ cat /sys/devices/platform/soc/soc\:rpi_rtc/rtc/rtc0/battery_voltage
2886321
In case things change on a future update, the instructions mostly came from here: https://www.raspberrypi.com/documentation/computers/raspberry-pi.html#enable-battery-charging
Maybe there is a simpler way to do this without needing to use a laptop? I’m not too familiar with HomeAssistant yet.
It doesn’t. I get a battery charge voltage when I boot Pi OS from SD card but when I boot Home Assistant OS from NVME the rtc0/charging_voltage is 0
I guess we need HA OS to add support to enable charging.
Didn’t work for me. But we’re up to HA OS 14.1 now.
Is there an open issue for this under HA OS?
This has been working for me with HassOS booting from an SSD. I’ve been using command_line: sensors to monitor battery and charge voltage, Unfortunately, something broke with HassOS 16.0. My command_line sensor is still working for the Pi5 fan speed, but the ones for battery and charge volts don’t anymore. :roll_eyes:
Found a fix. Needed to edit the path on the commands a bit. Here’s what I’m using in my configuration.yaml if anyone is interested.
command_line:
  - sensor:
      name: Pi5 Fan Speed
      unique_id: Pi5_fan_rpm
      scan_interval: 10
      command: 'cat /sys/devices/platform/cooling_fan/hwmon/*/fan1_input'
      unit_of_measurement: "RPM"
      value_template: "{{value}}"
  - sensor:
      unique_id: Pi5_RTC_Volts
      scan_interval: 60
      command: 'cat /sys/devices/platform/soc@*/soc@*:rpi_rtc/rtc/rtc0/battery_voltage'
      unit_of_measurement: "V"
      value_template: "{{ value | multiply(0.000001) | round(4) }}"
  - sensor:
      name: RTC Charge Volts
      unique_id: Pi5_RTC_ChargeV
      scan_interval: 60
      command: 'cat /sys/devices/platform/soc@*/soc@*:rpi_rtc/rtc/rtc0/charging_voltage'
