Has anybody been able to set up sensors for the rpi 5 to report on CPU, memory, SSD storage, etc.? I tried the Mysensors integration but it cannot access the rpi5 on the ip. If I recall this was quite easy to accomplish on previous pi’s.
The only intrgration picked up is the Raspberry Pi power supply checker which I don’t know what it’s for… If you don’t have power you wont be able to access anything.
Any help or ideas will be appreciated.
Just use the built in System Monitor integration.
Once installed, simply enable the entities that you’d like to monitor, like Processor Temperature, Processor Usage, Free Memory, etc…
Thanks. Got it working.
