Hi
I have seen that a SSD can be added to the Raspberry Pi . Is there a tutorial to add an SSD drive to Raspberry PI and installing HA
Help and comments will be appreciated
Hi
I have not found one but I have done it. I had a spare laptop SSD and bought a USB case from Amazon.
Basically, I flashed the SSD with Raspbian Lite using Etcher. It complained about a 120 GB SD Card, but it worked. When booted off the SD Card there is some configuration to get it to boot off USB. I think I need the SD Card removed to actually boot though.
https://www.raspberrypi.org/documentation/hardware/raspberrypi/bootmodes/msd.md
I did the same as bosborne. I have a RPi3b+. I used Win32 DiskImager to write a backup of my old installation (homeassistant already installed) to the SSD. Afterwards I used a USB2SATA to connect it to the raspberry, removed the SD card and the system booted successfully into my old installation.
Some hints:
Overall, it is a good idea to take this step and move your installation to a SSD drive.
Thank you guys , sounds good . Much appreciate it. Going to try it, just hope I choose the correct USB2SATA adaptor , I need to do some reading. Thanks
Here is what I bought.
Cool thanks
I use 32GB USB stick / thumb drive on my Raspberrys. Much more reliable than SD cards and much cheaper that SSD.
You won‘t get any benefits from an SSD, neither in speed nor in reliability.
Thanks appreciate it. I probably give that a try first as I have a good USB stick available . Just need to see how to get my Raspberry PI to boot from the stick and moving my HA to the stick.
That’s debatable, if you bought a cheap stick, some of those are good for about 8mb/sec write which would definitely be noticeable.
A good fast USB stick wouldn’t cost a lot less than what my SSD and cheap case cost anyway.
This is true, but in terms of reliability, I would rather trust a SSD, which is designed for intensive read/write processes in an operating system instead of an USB stick, which is designed for occasional transport of documents or media files.
In my past, I already killed multiple USB sticks with writing too much data on it, but never a SSD drive (they were cheap USB sticks though).
I already had the SSD sitting in a drawer so for me the case made sense. I had put a larger SSD in my laptop.
