I found this solution while trying to get my pi cam working, however it stops home assistant from booting up properly, saw the same boot issue with this config here: https://github.com/home-assistant/supervisor/issues/184#issuecomment-451596508
On my SD card the config.txt file is not in /boot rather in the top level directory. Wondering what is different about your install that makes this fix work. I’m running v 0.108.8 on a Pi 3B
How can I setting the Mmal camera that is connected to the PI with a ribbon cable in the home assistant platform?
I can try to connect PI camera that is connected to the PI with a ribbon cable adding command in configuration.yaml with the only line rpi_camera: but is not recognize in UI and in motionEye ( in home assistant )
