Hi There,
I’ve been running and testing andrewshilliday/garage-door-controller with no issues and it shows the door status correctly as closed or opened, also I am able to open and close the garage door using the web application with no problems.
Using the cover component in HA shows the door as open when is closed and vice-versa. Is there s solution for this issue? Can I do something at the configuration level to “force” the status as closed when is closed?
