Yes, it’s the age old “fun” of physical pin numbering vs BCM pin numbering (plus of course functional naming like TXD and RXD).
Concerning your other question - I think it’s only on or off, no percentage speed. I’ve not actually tried to put a variable voltage on the control lead and see what happens, but the thing looks so small and simple I expect it’s just a gating switch on the 5v/gnd connections to the fan and either on or off.
Hello, please help me, i can’t make this to work, I am very new to home assitant and i don’t understand a lot.
I copy paste the code but i get the next error:
Invalid config for [switch.command_line]: [name] is an invalid option for [switch.command_line]. Check: switch.command_line->name. (See ?, line ?).
Platform error switch.numeric_state - Integration 'numeric_state' not found.
this is the yaml config:
# Raspberry Pi Cooling Fan
switch:
- platform: rpi_gpio
ports:
4: RPI Cooling Fan
- platform: command_line
command: "/bin/cat /sys/class/thermal/thermal_zone0/temp"
unit_of_measurement: "°C"
value_template: '{{ (value | int / 1000) | int }}'
- alias: 'RPI Cooling Fan einschalten'
platform: numeric_state
entity_id: sensor.cpu_temp
above: 55
service: switch.turn_on
entity_id: switch.rpi_cooling_fan
- alias: 'Pi Lüfter ausschalten'
below: 36
service: switch.turn_off
Just above the - platform: command_line put sensor: fully indented to the left (in-line with your existing switch: header).
Similarly the other two items to turn the fan on and off are automations, not switches.Those are better entered via the GUI rather than by changing the configuration.yaml file.
Is the blue (connected to gpio 14) on Raspberry fan case not the same as RPM speed signal?
I’m trying to do the exact same thing with a 5V Noctua fan but I can’t get the rpi_gpio switch to do anything. The fan is running full speed as soon as the pi is powered. I would like to be able to turn on/off with a rpi_gpio switch.
