Raspberry Pi CPU Temperature on Home Assistant Over MQTT
I recently got interested in Home Assistant thanks to Bruh Automation on YouTube. I used Python to report the Raspberry Pi’s CPU Temperature over MQTT to Home Assistant. It’s just a simple script, but definitely shows how easy it is to get outside info into Home Assistant. Thank you for the grat software.
http://www.techsual.org/raspberry-pi/raspberry-pi-cpu-temperature-home-assistant-mqtt/
Hi Have a look at this.
https://home-assistant.io/components/sensor.command_line/#cpu-temperature
