Hi friends, new user here. Please, admin may move this post to the correct category if I’m a wee bit lost. Sorry for that.
I have set up Home Assistant in Docker on a Raspberry Pi 4 (Raspberry OS 64bit running of an ssd on usb) and I’m having some trouble to integrate my 433Mhz and Zwave usb devices. Things on my network such as Yamaha musiccast was automatically detected.
In Raspberry OS
cd /dev/serial/by-id/
/dev/serial/by-id $ ls -l
total 0
lrwxrwxrwx 1 root root 13 9 jan 15.32 usb-RFXCOM_RFXtrx433XL_DO5OP3V5-if00-port0 -> ../../ttyUSB0
lrwxrwxrwx 1 root root 13 9 jan 15.32 usb-Silicon_Labs_CP2102N_USB_to_UART_Bridge_Controller_1e914fd02487ec118153e93719c2d21c-if00-port0 -> ../../ttyUSB1
That is a Rfxcom 433 device and an Aeotec Z-stick 7 plugged directrly in the Pi
In my docker-compose.yml I have added two devices, and rebooted the Pi.
version: '2.1'
services:
homeassistant:
image: lscr.io/linuxserver/homeassistant
container_name: homeassistant
network_mode: host
environment:
- PUID=1000
- PGID=1000
- TZ=Europe/Stockholm
volumes:
- /home/miles/docker/homeAssistant/data:/config
restart: unless-stopped
devices:
- /dev/ttyUSB0:/dev/ttyUSB0
- /dev/ttyUSB1:/dev/ttyUSB1
In Home Assistant gui I went to Settings - Devices and services - Add integration and found Rfxcom, then it asks bout the usb path, what should I enter? So far I have tried /dev/ttyAMC0 ttyAMC0 /dev/ttyUSB0 /ttyUSB0
I’ve run out of google juice and would appreciate a guide forward.
