Anyways, I’m using HassOS on a RPI 4. I would like to be able to take advantage of this case’s power button. Is there a way I can incorporate this function in the existing HassOS buildroot environment? I’m fairly familiar with embedded linux but I’m still quite new to buildroot (only built one OS with it).
Just an update. I loaded Raspbian on the RPI4 and installed the Argon One script. As much as I like the design on this case, the fan just doesn’t keep the RPI4 cool enough for me. Could just be my opinion, but the case still gets quite hot. I have since moved the HA RPI4 to a standard CanaKit case (the one that came with the RPI4) and it’s cooling just fine. I’ll continue experimenting with the Argon One case as a RetroPi unit or something.
It takes some time to shutdown HA…
But, at some point, it’s shut down… But the led light of the argon case still is red.
So, I don’t really know if ha is completely down…
Only, when I connect a screen, I can see that after a long time, nothing happens, and I can safely cut the power. Someone any idea?
