I’m new in Home Assistant, I tried to make a rpi gpio switch for test, later I want to make the garden watering system out of this project. I made everything just like it write down in Raspberry “Pi GPIO Switch” but always get the error.
homeassistant:
# Name of the location where Home Assistant is running
# Location required to calculate the time the sun rises and sets
latitude: 0
longitude: 0
# Impacts weather/sunrise data (altitude above sea level in meters)
elevation: 0
# metric for Metric, imperial for Imperial
unit_system: metric
# Pick yours from here: http://en.wikipedia.org/wiki/List_of_tz_database_time_zones
time_zone: UTC
# Customization file
customize: !include customize.yaml
# Show links to resources in log and frontend
introduction:
# Enables the frontend
frontend:
# Enables configuration UI
config:
http:
# Secrets are defined in the file secrets.yaml
# api_password: !secret http_password
# Uncomment this if you are using SSL/TLS, running in Docker container, etc.
# base_url: example.duckdns.org:8123
# Checks for available updates
# Note: This component will send some information about your system to
# the developers to assist with development of Home Assistant.
# For more information, please see:
# https://home-assistant.io/blog/2016/10/25/explaining-the-updater/
updater:
# Optional, allows Home Assistant developers to focus on popular components.
# include_used_components: true
# Discover some devices automatically
discovery:
# Allows you to issue voice commands from the frontend in enabled browsers
conversation:
# Enables support for tracking state changes over time
history:
# View all events in a logbook
logbook:
# Enables a map showing the location of tracked devices
map:
# Track the sun
sun:
# Weather prediction
- platform: yr
# Text to speech
tts:
- platform: google
# Cloud
cloud:
group: !include groups.yaml
script: !include scripts.yaml
# proba
switch:
- platform: rpi_gpio
ports:
10: elso
12: masodik
Thx for the reading again, if got any idea pls tell it to me!
Note that - platform is indented two spaces ports: should be directly below - platform: and the remaining bits should be indented two spaces from where ports: is.
Spacing if very important in yaml pay close attention to it.
Did you run the config checker before you restarted? It often will flag items like this and tell you the exact line to review.
2018-07-18 18:29:25 WARNING (MainThread) [homeassistant.components.http] You have been advised to set http.api_password.
2018-07-18 18:29:45 WARNING (MainThread) [homeassistant.setup] Setup of config is taking over 10 seconds.
2018-07-18 18:30:02 ERROR (MainThread) [homeassistant.setup] Error during setup of component rpi_gpio
File “/usr/lib/python3.6/site-packages/homeassistant/setup.py”, line 146, in _async_setup_component
component.setup, hass, processed_config) # type: ignore
File “/usr/lib/python3.6/concurrent/futures/thread.py”, line 56, in run
File “/usr/lib/python3.6/site-packages/homeassistant/components/rpi_gpio.py”, line 22, in setup
import RPi.GPIO as GPIO
RuntimeError: This module can only be run on a Raspberry Pi!
2018-07-18 18:30:02 ERROR (MainThread) [homeassistant.setup] Unable to setup dependencies of switch.rpi_gpio. Setup failed for dependencies: rpi_gpio
2018-07-18 18:30:02 ERROR (MainThread) [homeassistant.setup] Unable to prepare setup for platform switch.rpi_gpio: Could not setup all dependencies.
2018-07-18 18:30:16 WARNING (SyncWorker_5) [netdisco.ssdp] Found malformed XML at http://192.168.2.34:47816:
invalid request
Is this mean the Home Assistant thinks this is not a PI? ( RPi 3B+ what I use, and the newest version of Home Assistant)
