My home assistant log hasn’t been written to since the reboot. HA doesn’t does run via systemctl start homeassistant.service because systemd is not the init system. I checked the /etc/rc directories and find nothing hass related. I googled for manual start up, command line start up and nothing works. My yaml config file has 2021 timestamp, so it is not that. Docker is running. syslog reveals nothing. I should be able to figure this out, but I am having trouble.
What are we supposed to do with posts like this. Besides the fact that you seem to run HA Container (because you mention Docker), there is no piece of information that lets you you help you.
- What OS is HA installed on ?
- How did you install HA ? I presume HA Container because you talk about Docker, but to be sure.
It is an HA container and the OS is rasp pi - Linux pi 5.10.103-v7l+ #1529 SMP Tue Mar 8 12:24:00 GMT 2022 armv7l GNU/Linux. Thanks
