Just got my first raspberry pi and installed the full raspbian jessie onto it. Im trying to install home assistant using the all-in-one installer and im getting this
Exception:
File "/usr/lib/python2.7/dist-packages/pip/basecommand.py", line 122, in main
status = self.run(options, args)
File "/usr/lib/python2.7/dist-packages/pip/commands/install.py", line 290, in run
requirement_set.prepare_files(finder, force_root_egg_info=self.bundle, bundle=self.bundle)
File "/usr/lib/python2.7/dist-packages/pip/req.py", line 1178, in prepare_files
url = finder.find_requirement(req_to_install, upgrade=self.upgrade)
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 194, in find_requirement
page = self._get_page(main_index_url, req)
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 568, in _get_page
session=self.session,
File "/usr/lib/python2.7/dist-packages/pip/index.py", line 694, in get_page
req, link, "connection error: %s" % exc, url,
TypeError: __str__ returned non-string (type Error)
Storing debug log for failure in /root/.pip/pip.log
When i first got the pi it had “noobs” on it and i used that to install raspbian. Ran into this issue so i thought maybe i should try getting the image directly from the raspbian site and loading it myself. So i finished doing that but im still having the exact same issue as before. I’ve watched 3 different tutorials from bruh and followed the instructions that are given for installing to raspberry pi on home assistant website. Any help is appreciated.
