Raspberry Pi installation
I just purchased a RPi 4b and then followed this guide: https://www.home-assistant.io/installation/raspberrypi
I flashed MicroSD card using Balena Etcher. Inserted it into my RPi, connected LAN cable and HDMI. Then I connected the power supply to start the computer.
Until now everything went fine. But after booting up the computer, I only got this screen:
Is it correct or not? I don’t understand the next steps. Where should I access http://homeassistant.local:8123/ ? On another computer in a web browser? I have no idea what should I expect. Should RPi boot to a GUI or will be running only as a server and I will access the GUI from another computer (using a browser)?
As a newbie I am missing these information and cannot realize, what’s wrong. Thank you.
Yes. The HA installation itself comes without a GUI.
Thank you. I flashed the SD card again and started from scratch and this time everything is working fine. I think this should be mentioned in the guide. The flashing of SD card is described very well, but this last step is not really clear.
