I installed adguard directly on my OS bypassing the one that is available in the HA add-ons for the supervised variant.
Is Systemd-Resolved even needed? I do not see any issues.
I had to disable Systemd-Resolved since it was using port 53 by default.
sudo systemctl stop systemd-resolved
This auto-removed two services
Removed /etc/systemd/system/multi-user.target.wants/systemd=resolved.service.
Removed /etc/systemd/system/dbus-org.freedesktop.resolvel.service.
Now when I load home assistant i get the repair warning for systemd-resolved, but it allows for me to use adguard.
If I run:
sudo systemctl start systemd-resolved
with adguard stopped it does not rebuild the services in those two locations. Do I just create symbolic links to fix it? If so what is the path for the systemd-resolved?
