I am using homeassistant supervised on a Raspberry pi 4. I basically use the pi for homeassistant. But as I also use the same pi for internet browsing and other purposes, I have this question.
Can I use Home assistant OS as the primary OS on the pi4 and install Raspberry pi OS on docker. This way I can shutdown the docker pi os when not required.
Can the docker pi os gui be used on the pi with keyboard and mouse or I need to use it as a VNC terminal.
