Raspberry Pi + RaspBee II - HAOS Deconz integrations
[Newbie warning]
I am running HAOS (core-2021.10.6) on a Raspberry Pi (4, 8GB) and installed the RaspBee II.
When I add the deCONZ integration for HAOS, I receive the following dialogue:
## Link with deCONZ
Unlock your deCONZ gateway to register with Home Assistant.
1. Go to deCONZ Settings → Gateway → Advanced
2. Press “Authenticate app” button
Couldn’t get an API key
How do I communicate with the RaspBee II to authenticate and adding the API key?
The instruction mention a file config.txt in the root of the SD card, no such file exist.
it is in /boot
Easiest way : shutdown HAOS, insert SD card in a Windows Computer, edit config.txt there, reinsert in Pi
You need to install the deconz add-on first, you should find it in the add-on store.
Hi @francisp there is no /boot folder either.
Hi @Burningstone I did, and set the Containers to default values. Any suggestions on values?
!fixed
Thank you for your guidance.
My raspbee II replace the Xiaomi GW and the Philips Hue, I am very pleased.
I beg the question though, why put a config.txt file in the root that cannot be reached by ssh or a samba share? I borrowed a PC to be able to reach the root directory.
